Please help!!!!!
Old Sep 20, 2016 | 06:55 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by soft 02
No but it will tell you if its brass, aluminum, copper or steel. That will help you know where to look.
Well, A good lit magnifier and magnet would do the same... I doubt you'll find copper unless it was under the chrome. You forgot chrome.. If depending on the bike, some stuff could be chewed off the an inner cover, like rockers or cam..
Old Sep 20, 2016 | 09:12 PM
djl's Avatar
djl
Originally Posted by bwoltz
So if you're seeing flakes in the oil, what is sending the oil off to be analyzed gonna do? Tell you everything is OK?
Well, pretty obvious things are not OK but I would like to try and identify the source of the flakes.
If you used roller rockers, you were lucky it even started. Rocker cover needs clearance. Bike needs tune. Flakes mean you need to pull the cam case, oil pan and clean out the swarf. Late model TC will clear a 585. Early 5 speeds probably won't.
We still don't know the MY but if '05 or later 585, with rollers should clear. If an earlier model, motor shouldn't have started. Perhaps a bit premature to jump to pulling the pan?? We will wait and see; maybe that is what will be required. I am not so sure the "swarf" wasn't there before the modifications; guess we will never know.......
Old Sep 21, 2016 | 01:03 PM
Mike Lawless's Avatar
Mike Lawless
"Flake" is a relative term.
On my drag race motors after an initial fire-up (new cam, lifters, rings, etc) it's common to have a bit of a metallic sheen to the oil. But that's with a flat tappet cam and they need break in so they get to "know each other."
A flake big enough to to feel between my fingertips.....if there's more than one or two, (espeicially if it's magnetic) the motor's coming back apart. From outside to in until I find the source. Sometimes the work reveals nothing. Most times it does. It can be a pain in the a$$, but it's just work, and it can save a big chunk o' change down the road. My rule is simple.....assume nothing.
Old Sep 21, 2016 | 01:28 PM
Max Headflow
You actually bring up a good point. What good is oil testing goingt to do during breakin?? You want probably 2 or 3 oil changes and some a couple thousand miles before all the moon dust is gone.
Old Sep 21, 2016 | 03:59 PM
djl's Avatar
djl
Seems the OP is on the verge of a catastrophic failure, even though we still don't know what the "flakes" are, how big they are or where they are coming from and the only way to avoid this certain death is to pull the top end, clean it up, flush the crank case, pull and clean the pan, pull and clean the oil cooler (if it has one) as well as the supply and return lines, pull the cam chest, clean all the cam chest components and flush all the internal oil passages in the motor to insure that all flakes have been removed. Put her back together, fire the motor up and hope not to see any more flakes. Oh yeah, make sure that when putting the cam chest back together that there is a proper o-ring and seal between the pump and the scavenge port and that the oil pump is properly aligned. That way, if you should see any flakes, at least the motor won't be sumping............
Old Sep 21, 2016 | 06:55 PM
roganloadman's Avatar
roganloadman
3rd Gear
Originally Posted by ChopperGuf
Just put in the S&S 107 kit with 585 cams adjustable pushrods rocker arms lifters fueling HP oil pump and cam plate. Having over heating problems not getting all the power when I turn the throttle and finding flakes in my oil please help.
how do you know it's overheating? Has it been tuned?
Old Sep 24, 2016 | 02:39 PM
ChopperGuf's Avatar
ChopperGuf
4th Gear
Thanks for all the help bike is in the shop now. Once they find the problem I will post it up for every one knows what the problem is and how to fix it.
Old Sep 26, 2016 | 10:27 AM
djl's Avatar
djl
Is this shop where the original work was done?
Old Sep 26, 2016 | 12:25 PM
ChopperGuf's Avatar
ChopperGuf
4th Gear
No the oringal work was done by a frien. Bike runs great till it starts to overheated so got tried of deals ng with it.
Old Sep 27, 2016 | 09:15 PM
ChopperGuf's Avatar
ChopperGuf
4th Gear
Update for bike oil n metal flakes all in the engine shop says I need a new engine. Jack up my whole kit. On that note anyone know someone who is selling an engine.
