Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Hey All,
A buddy of mine has a 2012 Limited (Bagger)
at 3000 rpm's in 5th gear , there is an intermittent fluttering noise
that is heard in all ranges of throttle... except deceleration...
I rode the bike for 30 miles and I cant figure it out...
Never heard anything like this...
Best Guess do describe it is: sounds like the exhaust is charging thru a check valve , once the check valve opens you hear a FLUMP FLUMP FLUMP FLUMP... "Pause" repeat.....
Has anyone experienced this or have any idea how to remedy it....
Thanks E. Glide Guy
