Tire Shredder Heads
Old Nov 12, 2016 | 08:49 PM
  #31
yobtaf103's Avatar
yobtaf103
for reference, just used the 110 bolt on HD cyl/pistons to upgrade my 96" Fatboy2011 with port/valve job on stock 103 heads 10.6 comp, with se 58mm tb, T-Man 625 cams supermeg 2-1
126hp/124tq
Old Nov 13, 2016 | 12:06 AM
  #32
Breakout110's Avatar
Breakout110
The DIN correction factor will show 6-7% higher than STD.
Still great numbers. I would love to get my 10.2 CR up to around 10.7
Old Nov 13, 2016 | 12:17 AM
  #33
Breakout110
Forgot to ask what valve springs you went with?
Old Nov 14, 2016 | 01:43 AM
  #34
yobtaf103's Avatar
yobtaf103
Yep got a sheet in sae 3/3 less than din, springs AV&V beehive
Old Nov 30, 2016 | 11:20 AM
  #35
MMXIWG's Avatar
MMXIWG
Originally Posted by flanigans45
Ok Stage 5 kit is A 103 engine block up grade with out boring the block. The pistons in the kit is flat tops ,compression is 10.2 with CNC factory ported heads , Intake valve is oversized to 1.875". And about 87cc combustion chamber. 110 heads has 95cc combustion chamber witch will lower the compression to about 9.2 .The bigger valves will lower vacuum witch in turn lower low in torque. To put 110 heads on will need to install 10.5 piston for the heads. The stage 5 Kit works great . I run one.
I have a partially stupid question. While I know the 110 motors run warmer, my EITMS is kicking in way sooner with the Stage 5 kit than it did before. Is yours running significantly warmer or do you think the Harley download may have lowered the EITMS on temperature on my bike?
Old Nov 30, 2016 | 06:08 PM
  #36
flanigans45's Avatar
flanigans45
I used Calibration 617SGT204 Stage 5. EITMS is turned off on the down load.
Old Nov 30, 2016 | 06:25 PM
  #37
HDSAE60's Avatar
HDSAE60
All I see in the 17 SE parts book is stage IV, what is a stage 5?
  #38
flanigans45
Who did the tune . EITMS only works at idle. If air/fuel is lean it will run hotter. I set my air/fuel to 13.7 at idle to run cooler.
Old Nov 30, 2016 | 06:30 PM
  #39
flanigans45
Is a 103 upgrade to a 110 - Has 10.2 compression -cams -58mm TBI- Factory cnc ported heads.
Old Nov 30, 2016 | 06:32 PM
  #40
flanigans45
Part # 92500037.
