CAM only for a stock 103
Old Dec 22, 2016 | 10:01 AM
Lunchboxx's Avatar
Lunchboxx
Default CAM only for a stock 103
What is a good CAM only upgrade. 2016 Dyna Lowrider ?
That will still be good when I can afford to get the head work done.
Old Dec 22, 2016 | 10:21 AM
djl's Avatar
djl
Originally Posted by Lunchboxx
What is a good CAM only upgrade. 2016 Dyna Lowrider ? That will still be good when I can afford to get the head work done.
There are several; where do you want the power? Looking for TQ or HP?
Old Dec 22, 2016 | 10:36 PM
cdonis's Avatar
cdonis
Wait and do both at one time. Ask me how I know.
Old Dec 22, 2016 | 11:12 PM
94 ultra's Avatar
94 ultra
pop on some Andrews 48H maybe
or some Woods 555
that will help especially with a Power Vision with Plug and Play Map from Fuel Moto
Old Dec 23, 2016 | 05:04 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
[QUOTE=Lunchboxx;15774318]What is a good CAM only upgrade. 2016 Dyna Lowrider ?
That will still be good when I can afford to get the head work done.[/QU
Depending on where you want to go, an Andrews 57, or an S&S .570 are on the list at 10-10.2 cr.
Scott
Old Dec 23, 2016 | 06:24 AM
ntraindavefl's Avatar
ntraindavefl
Try the vance Hines 575 cam set.
Old Dec 23, 2016 | 09:05 AM
djl's Avatar
djl
Steve Cole, the TTS Mastertune guy, came out with the TTS 100 a while back; great for low and mid range, stop light to stop light power. He has added a new cam, TTS 150 IIRC that carrys out further. Specifically designed for heavier touring bikes but could be great in a Dyna as a cam only upgrade.
Old Dec 23, 2016 | 11:31 AM
Lunchboxx's Avatar
Lunchboxx
I am just checking my options right now
Old Dec 23, 2016 | 01:35 PM
94 ultra's Avatar
94 ultra
So the Andrews 57 is good for a stock Dyna and the andrews 48 for a stock Rushmore twin Cooled (10.2 compression)??
Is that your opinion Scott?
Thanks
Old Dec 23, 2016 | 01:54 PM
qtrracer's Avatar
qtrracer
After riding a 2014 FLHX with TTS 100's, not mine but I have ridden it quite a bit, I would not hesitate in trying the TTS-150's in a Dyna. The TTS-100's are a homerun in the touring platform as a cam only type upgrade
