Oil for break in
Old Dec 27, 2016 | 11:30 PM
2deuceguy's Avatar
2deuceguy
Originally Posted by Hillsidecycle.com
Any good quality 20W50 petroleum motorcycle oil.
We use/stock Spectro 20W50 here, and use/stock Red Line for our synthetics.
We are shop, that does this everyday, not an individual owner
What method do you use for changing oil on a fresh engine? Similar to above with every 300 miles or? Also, do you guys do it differently if the bottom end has been gone through as opposed to just doing a big bore?
Old Dec 28, 2016 | 06:16 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
[QUOTE=2deuceguy;15787305]What method do you use for changing oil on a fresh engine? Similar to above with every 300 miles or? Also, do you guys do it differently if the bottom end has been gone through as opposed to just doing a big bore?[/QUOT
Same/same +/-.
Scott
Old Jan 17, 2017 | 09:44 AM
Erilflynn's Avatar
Erilflynn
Originally Posted by djl
Shell Rotella 15W40.
Coming from many years riding Vulcans I can tell you many Kawi guys love Rotella 5/40 full synthetic for their bikes. Also has the motorcycle label (JASO?)
Old Jan 17, 2017 | 11:27 AM
98hotrodfatboy's Avatar
98hotrodfatboy
There is a big difference between water cooled and air cooled engines....
Old Jan 17, 2017 | 11:45 AM
Erilflynn's Avatar
Erilflynn
Being brand new to Harley I constantly forget this....thanks.
Old Jan 17, 2017 | 11:49 AM
HotRodNut's Avatar
HotRodNut
I'm still convinced to use straight Dino or a blend at least for break-in.
Point being is I had a Boss 302 that came from the factory with full synthetic and it used 3 quarts of oil in the first 1000 miles. After break-in it was ok but those first 1000 was scary.
Breaking in with Dino I never had an issue of oil usage.
Old Jan 17, 2017 | 02:10 PM
13RoadKing's Avatar
13RoadKing
deleted
Old Jan 17, 2017 | 06:46 PM
qtrracer's Avatar
qtrracer
I have total respect for any professional that builds motors for a living. Now having said that that on my last build 107" high comp, over 11-1, 9f cams, I used Mobil 1 because I had it on hand. Went fine with no issues. Don't overthink it. Getting it tuned properly at the get go will have way more benefit over what type oil you use. Mine was broke in on dyno. It's been flawless since.
pococj
Oil Archive (no new posts)
83
Jan 29, 2024 12:36 PM
Bbbadboy
Nov 3, 2013 08:43 PM
DHart
Oct 6, 2009 11:28 AM
reesestewww
Aug 19, 2009 02:44 PM
bigstevex4
Jun 1, 2008 04:44 PM
