Special tools for Rocker Base upgrade & Lifter Replacement
Old Jan 19, 2017 | 08:19 PM
ColoStreetGlide's Avatar
ColoStreetGlide
Originally Posted by PeterV
(Keep torque wrench at 90 to length of extension added, so torque wrench doesn't misread value)
Great shot! Mine look a bit different than that as they have nuts as well thought they don't seem very useable on that side. Might be welding up a tool if I don't get something in time.
Old Jan 19, 2017 | 08:23 PM
QC's Avatar
QC
I think so. I had a real bad rattle, specially when hot, generally between 2400-2900 rpm, mostly at light loads. All I have now is a little ticking that is barely noticable, to let me know it's still running. The lack of noise is amazing.
Old Feb 14, 2017 | 07:20 PM
ColoStreetGlide
Hey guys, I'm in there! One question, I was reading through the manual today and I did not see that it called for loctite on the the rocker base bolts, do you guys Loctite? The new breather bolts seem to already have some on them.
Old Feb 14, 2017 | 07:41 PM
ROCKOUT Rocker Products
Sponsor
Like you, I've never seen mention of it in the manual. I personally don't use it on the rocker support bolts, but do on the rocker cover bolts. I have heard reputable engine builders say yes, and no lol.
New bolts come with some dry coating on them, not positive if it's thread locker or thread lubricant. If you REALLY want to cover all bases, new bolts are about $1 each at the dealer.
John @ Rockout
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Feb 15, 2017 | 09:22 AM
2deuceguy's Avatar
2deuceguy
John @ Rockout
This is what I do also. I don't use loctite internally unless called for in the book, but do use blue on the cover bolts. Hopefully someone with more knowledge than myself will post their method.
Old Feb 15, 2017 | 09:30 AM
Uncle Larry's Avatar
Uncle Larry
This may help in understanding torque wrenches and extensions.
Sportstatler
Sep 1, 2025 05:26 PM
buddy67
Engine Mechanical Topics
Mar 11, 2019 11:38 AM
sinex
Sep 11, 2011 08:07 AM
MoChrome
Aug 29, 2010 11:21 AM
DGlide04
Exhaust System Topics
Feb 19, 2008 06:42 PM
