Melling JB-2079
Old Feb 24, 2017 | 03:10 PM
kylebryan's Avatar
kylebryan
Default Melling JB-2079
Picked up a set of Melling JB-2079 lifters today from Autozone (cost me $10 ea) for my 2010 FLHX. Can someone confirm what depth I should I preload these lifters? Will .120-.140 work for these?
Old Feb 24, 2017 | 05:04 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Never heard of the but if you have a dial indicator you can measure them.
Old Mar 3, 2017 | 11:30 AM
kylebryan's Avatar
kylebryan
anyone else have any info on these?
Old Mar 3, 2017 | 11:41 AM
98hotrodfatboy
I did do a little research on these when first posted and in another forum I found that because they are typically a small block Chevy lifter the oil port is only .077"as compared to HD and S&S that are a lot bigger because the differences in oil pressures. I can measure my HD and s&s lifters tonight and let you know if you want...
Old Mar 3, 2017 | 01:16 PM
djl's Avatar
djl
Here ya go.
Old Mar 5, 2017 | 10:31 AM
nhrider1's Avatar
nhrider1
Harley lifters have about 0.200" of total travel...so 0.120"-0.140" is fairly typical. If the Melling lifters have similar travel specs you will be fine.
You can measure the lifter travel before installing if you like, or you can verify the distance (or amount of turns) from zero play to bottomed out if in doubt. Make sure the lifter fully bleeds down if you chose this method.
Old Mar 12, 2017 | 04:44 PM
kylebryan's Avatar
kylebryan
i knew the oil hole was a bit smaller on the melling lifter but i had planned on swapping out the cups from my stock lifters to the SBC lifters to make up the difference.
Old Mar 13, 2017 | 06:08 AM
98hotrodfatboy
Not all lifters are the same. I know that the cups between my HD and S&S lifters are a totally different design. Let alone the difference in the bores...
Old Mar 13, 2017 | 08:11 AM
kylebryan's Avatar
kylebryan
I'm sure you're right, but the melling and stock lifter cups are the same minus the oil hole size.
Old Mar 19, 2017 | 08:59 AM
kylebryan's Avatar
kylebryan
Installed the Melling lifters yesterday after swapping the cups over from my stock lifters. Seated the push rods at .125. This motor has never been this quiet! Pretty impressed with these $10 lifters.
Jbco2
Jun 18, 2013 11:08 AM
bbs15
Nov 27, 2011 03:41 PM
Buddy WMC
Dec 16, 2010 01:05 AM
Old Gunny
Exhaust System Topics
Apr 29, 2008 09:12 AM
