Why Replace Cam Bearings
Old Mar 5, 2017 | 03:02 PM
gdishman's Avatar
gdishman
Default Why Replace Cam Bearings
I am replacing the cams in my 2016 heritage to S&S 583 and was wonder why that they recommend replacing the cam bearings. I have not heard of any late model bearing failures. I can understand replacing them if the engine has high mileage because of wear. But what I have read they recommend to replace them what ever mileage you have. Can someone explain to me why they need to be replaced?
Old Mar 5, 2017 | 03:10 PM
jvella's Avatar
jvella
6th Gear
My guess would be the inner race between the two are different.
Old Mar 5, 2017 | 03:12 PM
NORTY FLATZ's Avatar
NORTY FLATZ
The OEM bearings don't offer enough carrying capacity for a cam shaft. The "bean counters" saw $1 saved by using a bearing that is substandard. Multiply that dollar by hundreds of thousands of motorcycles, and you see a real savings. Now, to the owners that really ride their bikes a lot, this bearing can cause issues.
Most of the bikes sold, become "garage Queens" with very little use. These owners don't even know/care about the cam bearing/wheel bearing/cam chain followers that other riders are aware of.
Old Mar 5, 2017 | 03:19 PM
Gozzie's Avatar
Gozzie
The cost of the bearings is very minimal. It's the tool to install them is what cost the most. If you can borrow or rent one then I would definitely change the bearings out. My humble opinion of course.
Old Mar 5, 2017 | 06:00 PM
Sisu's Avatar
Sisu
Mine was low mile when I changed cams and I left them in. I don't recall seeing anyone post problems about the newer 1" bearing going bad. I put a lot of hard miles on it and the cam bearings are still fine. The crank is a different story..
Old Mar 5, 2017 | 06:01 PM
djl's Avatar
djl
http://www.bigboyzheadporting.com/showthread.php?t=88
Old Mar 6, 2017 | 09:18 AM
nhrider1's Avatar
nhrider1
The link posted by DJL illustrates the difference. The factory bearings are not 'full compliment' bearings. They have fewer rollers, held in place with a cage. The 'full compliment' bearings (B-168 for newer HD's) have more rollers and no cage.
There have been many problems in the past with the reduced roller version, although newer riders may not be aware.
The stock bearings don't hold up well with performance camshafts, and in fact there were many failures with the stock cams.
It is a false economy to not replace the bearings with the full compliment style bearing when upgrading camshafts. That's why S&S, Andrews, and probably most aftermarket cam makers strongly recommend replacing the bearings.
Old Mar 6, 2017 | 09:23 AM
Uncle Larry's Avatar
Uncle Larry
^^^ B I N G O ... We have a winner ^^^
Old Mar 6, 2017 | 03:10 PM
rauchman's Avatar
rauchman
Is it safe to say, once the bearings are changed (assuming higher quality bearings were installed...Timkin, other?) that they don't again need to be changed upon reinstallation of existing or even newer cams?
Old Mar 6, 2017 | 03:28 PM
djl's Avatar
djl
Yes, with a couple of exceptions; high mileage and/or other motor damage that could result in debris traveling in the oil in which case, bigger issues to deal with.
