Piston ring question
Old Mar 29, 2017 | 10:03 PM
Hoytman1968's Avatar
Hoytman1968
Default Piston ring question
Do the screamin eagle forged pistons take a different ring set than the screamin eagle cast? Picked up some mint 95" forged pistons but not sure on the rings? Also what is best piston clearance to set the forged pistons at.
Old Mar 30, 2017 | 08:39 AM
djl's Avatar
djl
Harley has used cast rings, moly rings, etc., etc. Get a set of HD's titanium SST rings which is what is sold with their forged pistons. Set the pistons up at the manufacturers recommendation which is probably .0020"-.0030" and don't forget to check ring gap and adjust if necessary.
Old Mar 30, 2017 | 06:50 PM
Hoytman1968
Do you have the part number for the rings by chance?
​​​​​​​0
Old Mar 31, 2017 | 12:06 PM
Hoytman1968
Would the standard rings for cast pistons 95" work or is that a bad idea?
Old Mar 31, 2017 | 12:27 PM
djl's Avatar
djl
Honestly, I don't know. There could be differences in ring groove dimensions between cast and forged pistons so I would be wary of using a ring pack for cast pistons on a forged pistons. I do not know the PN for the HD titanium SST rings but do know that the titanium ring is the ring HD uses with their forged pistons.
I don't know who makes rings for the MoCo but Hastings does make cast and SS rings for HD OEM pistons; suggest you give them a call and have your piston PN handy.
Old Mar 31, 2017 | 03:05 PM
Hoytman1968
Thanks for the help. I did find arias makes rings for my piston number but they are like $60 for the set does that sound about right price wise?
Old Mar 31, 2017 | 04:17 PM
djl's Avatar
djl
Yes; a bit on the high side but not much.
Old Mar 31, 2017 | 04:39 PM
Mike Lawless's Avatar
Mike Lawless
I was looking thru my Total Seal catalog and they list ring widths of 1.5 x 1.5 x 3.0mm for 88" TCs (3.75" bore including oversizes to .020"). A 3.875 bore has ring widths listed as 1.5 x 1.5 x 2.5mm ring widths.
I've been using Total Seal in my drag car for nearly 20 years. Gapless design on either the top or second ring. My leak-down readings are typically less than 2%. Sometimes a little less.
But they are pricey. I'll pay $160 for a set for a 4 cylinder (3.701" bore. Slightly smaller than HD)
Mattbastard
General Topics/Tech Tips
May 29, 2019 06:29 PM
Meatpants
Shovelhead
Mar 27, 2017 07:28 PM
tanglefootrgu
Exhaust System Topics
Jun 10, 2010 12:50 AM
Americanbear
Oct 22, 2007 08:49 PM
Wyo_Wide_Glide
Jan 3, 2007 10:27 PM
