Cam swamp (stuck) mesh filter location?>
Old Apr 2, 2017 | 11:32 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by 2009blackpearle
I don't recall seeing a screen in my cam box when I had my bike apart. I don't see a screen in my service manual either.
The screen is only on counterbalanced motors.
Old Apr 5, 2017 | 05:14 AM
Gordon61's Avatar
Gordon61
BTW ...the screen is not mentioned in the 2014 softail manual at all ...the o-ring yes, screen no! doesn't even show it
If I remember correctly the screen came out stuck (with oil) to the cam plate when I did my cams, o-ring was still in hole
Old Apr 5, 2017 | 07:37 AM
roussfam's Avatar
roussfam
Originally Posted by Gozzie
If the o ring was still in place wouldn't that mean the screen was on top of it ?
Don't come here using logic to stir things up!
Old Apr 5, 2017 | 09:51 AM
Max Headflow
So where was the screen?
From the 00 softail SM.. Bet it's in the 14 SM someplace unless they stopped using them.
Old Apr 5, 2017 | 09:55 AM
Max Headflow
#2 looks to say that the screen goes in first.
Old Apr 5, 2017 | 10:22 AM
roussfam's Avatar
roussfam
Your right, It's very clear on that point. When all else fails, read the directions
Old Apr 5, 2017 | 04:48 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Originally Posted by Pepsimayn
And no, the dealer screwed up and got me the wrong service manual. Will be here in a few days. Knew I was going to hear that at least once!
So you tore into the engine blind, and here you are.
Good luck using Google to re assemble an engine.
Old Apr 6, 2017 | 06:18 PM
B Bop's Avatar
B Bop
Originally Posted by Rat Trap
Looks like it goes on top of the o-ring.
http://partsfinder.onlinemicrofiche....MSHAFT%20COVER
That's strange as I just pulled my cams Monday and my 2 small O-Rings are on the outside. I also checked my maintenance manual and it also shows O-Ring on outside, if you think about it, having the O-Rings on the outside seals port between cam plate orifice & filter. The way your diagram shows will not seal causing it to leak IMHO.
B Bop
2012 FLHR (Road King) Ember Red Sunglo & Merlo
Cruise Control, ABS, Chrome Aluminum Profile Laced Spoke Tubeless Wheels, Security Package, Saddle Bag LED Lid Spoilers, and an array of accessories that enhances nostalgic appearance & blood curdling performance.
A politician is a fellow who will lay down “your” life for his country
Old Apr 7, 2017 | 04:28 AM
Gordon61's Avatar
Gordon61
The screen came out with the cam plate, it was stuck to the face of the cam plate ...although thinking about that again, maybe the o-ring was stuck to the plate and the filter to it ...I really cant remember, sorry.
The filter definitely came out with the plate because I wondered what the hell it was ...it is NOT in the 2014 manual at all.
My apologies to HD, I know you are not supposed to reproduce their manuals and such but for the purpose of this confusion, these are the only two bits that mention those o-rings and the "cam post"
In the section about the oil pump it tells you to lube that o-ring but still no mention or pic of the screen ??!?? It's definitely there thou, that I am 100% sure of
Old Apr 7, 2017 | 04:34 AM
Gordon61's Avatar
Gordon61
It has to be on the outside really doesn't it
