Head removal with out disturbing base gaskets?
Old Apr 13, 2017 | 05:27 PM
Uncle Fuzzy's Avatar
Uncle Fuzzy
Default Head removal with out disturbing base gaskets?
What is the best way to remove a stubborn head from the cylinder without disturbing your base gaskets?
Get out the rubber mallet and start tapping??
Old Apr 13, 2017 | 05:59 PM
SgtMic's Avatar
SgtMic
I'd just plan in replacing the hg vs reusing them. If something went wrong, it's a lot of work for a 35 dollar part.
Old Apr 13, 2017 | 06:07 PM
Uncle Fuzzy
I'm replacing the head gaskets.
I didn't want to disturb the gaskets at the base of the cylinders.
Head is pretty stuck on there.
If I have to pull the cylinders it's gonna go bad..
Full 107"
And I'll have to sleep in the garage
Old Apr 13, 2017 | 06:40 PM
SgtMic's Avatar
SgtMic
Missed the base gasket part. If you have help, it might work to have him put pressure on the cylinders while you tap on the heads.
Old Apr 13, 2017 | 06:44 PM
Uncle Fuzzy
Hmmmm...
Maybe enlist the wife..
If the cylinders come up?
107...her fault
Your a genius
Old Apr 13, 2017 | 07:04 PM
aquadave's Avatar
aquadave
don't take the chance. I have a PHD in Law I graduated from Murphy's Law. If you loosen it and it has a chance to wiggle it'll leak. buy a set of rings and base gaskets do the top end while you're there.
Why are you pulling the heads?
Old Apr 13, 2017 | 07:07 PM
94 ultra's Avatar
94 ultra
Yep there it is
Now you got to get the 107 kit
Because you will be worried about it
I know that I am as I never have thought about this aspect
I thought about just doing my heads and cams
It is a great question
dammit
Do it all right the first time I guess
Old Apr 13, 2017 | 07:08 PM
Uncle Fuzzy
Pulling them for a street port. Have a buddy in a shop that'll do em for me on the cheap.
Wasn't planning on doing a top full top end as the motor only has 18k on it.
It'd be a shame to get it all apart for only a ring job..
But a CI upgrade just isn't in the budget right now
Old Apr 13, 2017 | 07:18 PM
Uncle Fuzzy
Not to mention I just dropped the coin over the winter for all the stage 2 parts with Andrews 48H as I was planning on keeping it mostly stock past that point. The headwork was only to be a quick port.. No decking or any other changes.
Sooo...
New cams too as the Andrews are designed for the stock 9.2:1 static.
Old Apr 13, 2017 | 07:37 PM
Mike Lawless's Avatar
Mike Lawless
arent they an o-ring seal?
