Adjustable push rods
Old May 17, 2017 | 01:38 PM
stal94gt's Avatar
stal94gt
Default Adjustable push rods
I recently installed a set of cr575 cams and S&s standard lifters in my 2007 night train and all went well. I reused my original pushrods but think I can quiet up the chatter by switching out to a set of adjustable push rods. I am looking into the fuelmoto pushrods but am curious if there are better ones out there. I will be removing the rocker boxes so I don't need a set of quicky push rods
Old May 17, 2017 | 03:39 PM
LXT's Avatar
LXT
Fuel Moto`s are Smith Brothers I believe - I bought mine from them, you wont find a better adjustable pushrod - adjusting them can be a PITA but well worth it IMO.
Talk with Jamie - good guy he`ll steer you right
Old May 17, 2017 | 05:16 PM
cvaria's Avatar
cvaria
i like my s&s rods. used them on my sportster. came with new pushrod covers too. will be happily using them on my dyna soon #106-6051.
Amazon Amazon
will it make your bike quiet? i don't know
Old May 18, 2017 | 11:04 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Just get the S&S standard adjustables they are machined to properly fit your S&S lifters and set the pre load to. 140"..... You'll be happy you did...
Old May 19, 2017 | 10:59 AM
Lunchboxx's Avatar
Lunchboxx
S&S Set preload to ~.140 Which is about 4.5 turns
Old May 19, 2017 | 02:54 PM
Tat2u's Avatar
Tat2u
Yep this...
Old May 26, 2017 | 02:24 PM
stal94gt's Avatar
stal94gt
I ended up going with fuelmoto pushrods but not quite sure how many flats/ turns I need to do to get .140 inches of preload
Old May 26, 2017 | 02:38 PM
hrdtail78's Avatar
hrdtail78
3 turns are .0989. Each turn is .0329666666. 4 turns will get you to .13186666666. Or you could go 10-11 flats from bottom lash. I prefer to set mid travel and do 3 full turns from bottom.
Old May 26, 2017 | 03:22 PM
94 ultra's Avatar
94 ultra
So would you get the S&S standard or Quickees?
not to hijack
Old May 26, 2017 | 03:59 PM
stal94gt's Avatar
stal94gt
not to hijack
It depends on if you want to pull the gas tank off and go threw the rocker boxes or cut the stock pushrods and install them that way. IMO the extra money for quick pushrods and tubes is not worth it. I went with quick pushrods cause I had a discount with fuel moto and got their pushrods for the same price. Fuelmoto pushrods can use the oem push rod covers cutting down on price
