Specialty Tools/ Cam Swap ?'s
I am going to change the cams in my 09 FLHTC. I will change to the S&S lifters and pushrods. That brings the first question. Anti rotation pins? Will the new S&S lifters come with them? Should I order new ones to have on hand? The next questions. Is there a place to rent/beg/borrow/steal a cam bearing puller/installer? The cam locking tool? The bike has 36K miles. I will replace the cam tensioners while I am at it. Is there anything else to look at while I am in that part of the motor?
My list of stuff. Am I missing anything?
Exhaust gaskets
Oil pump O rings
Lifter cover gaskets
Cam cover gasket
S&S adjustable pushrod kit, Includes new covers, O rings, Cover gaskets.
48H cams with bearings
Assy lube
Inner and outer tensioners
Blue and red Lok Tite
Exhaust gaskets
Oil pump O rings
Cam cover gasket
Assy lube
Received 2,196 Likes
i just used these recently:
puller/installer
http://www.ebay.com/itm/271351607654...%3AMEBIDX%3AIT
gear lock
puller/installer
gear lock
Inner cam bearing installer/puller appeared from
http://www.heartlandproducts.net/hea...m-bearing-set/
yeah, the flathead scew driver/ fin method can be a pain.
2004Sierra
03-31-2013 08:30 PM
