cam change help
Old Jul 29, 2015 | 07:19 PM
glider1993's Avatar
glider1993
Default cam change help
Changing cams in my 13 SG. Here is the list I come up with. Any thing I Missed please let me know so I wont have any hold ups.
  • Andrews 57h cam
  • S&S Standard lifters
  • S&S quickie pushrods with covers
  • Torrington b-168 cam bearings
  • cam cover gasket, lifter base cover gaskets, and exhaust gasket
  • cam bearing remove and install tool-Heartland Products
  • Tune from fuel moto
  • oil and filter
  • assembly lube
  • cam gear holding tool
  • loctite and torque wrenches
  1. What O-rings behind the chest do I need and how many, is it 3 total?
  2. Is the Heartland bearing tool a good tool?
  3. Do you have to soak the lifters in oil overnight before install?
Does this list look complete or what am I missing....
Thanks
Old Jul 29, 2015 | 07:43 PM
torchmaster's Avatar
torchmaster
Cam gear locking tool.
Old Jul 29, 2015 | 07:49 PM
Bikerscum's Avatar
Bikerscum
There are 3 o-rings inside, one of the online parts diagrams like Granite HD will show you. There is a certain way to put the oil pump o-ring on... I can't remember for sure but I think you slide it over the tube rather than putting it in the hole.
You'll need some way of locking the cam sprockets while you loosen the bolts. I bought the tool from George's Garage, was about 25 bux I think, works well.
The Heartland tool is a good one. Make sure you get the later model that's cut out so you can see what you're doing. It's pretty tense as you put more & more pressure on the bolt until the bearing finally pops.
Get to youtube & watch the video from S&S, very complete.
Old Jul 29, 2015 | 07:50 PM
glider1993's Avatar
glider1993
I'll add this to the list. Thanks
Old Jul 29, 2015 | 07:53 PM
glider1993's Avatar
glider1993
Soak lifters or not
Old Jul 29, 2015 | 07:55 PM
Bikerscum's Avatar
Bikerscum
Oh, and on the Heartland tool...
Mine did not want to pop into the bearings for removal. The instructions tell you to tap them in. I tapped, and TAPPED, felt like I was going to damage something if I hit any harder. I ended up taking the tool over to a vice & squeezing it closed just a touch, then it worked great. You have to be careful here, it's hardened steel & too much collapsing can snap it.
Maybe I just got a tight one.
My S&S lifters came packed in oil. I used a squirt can to fill them up .
Old Jul 29, 2015 | 07:56 PM
hdultra2010's Avatar
hdultra2010
well , i did mine a few months ago( 2010 ultra classic), but i didnt change no bearing , no push rod or even a lifters.
i bought a james gasket kit that have everything in it.
the oring that u need are 3 . 2 of them are small size and one is big (1/2 in and 3/4in), but like i said i had them in kit.
u will need a locking tool , bought on ebay for 20$. make it alot easier .
u will need a gasket for the exhaust . and adjustable push rod if not using the one u have .
Old Jul 29, 2015 | 08:02 PM
Bikerscum's Avatar
Bikerscum
And red & blue loctite.
And a torque wrench.
Old Jul 29, 2015 | 08:12 PM
glider1993's Avatar
glider1993
Got plenty of loctite and hand tools. I'll remember that about the heartland tool. Thanks.
I'm not removing rocker boxes so that's why I'm installing adjustables.
Old Jul 29, 2015 | 08:37 PM
Bikerdog44's Avatar
Bikerdog44
Did the Andrew 57 back in May. Real big difference, a lot of pull.
You might want to change out the lifters while your at it, I put the S&S HP lifters in. It helps with the noise from the Cams.
I also added a SS filter so the bike can breath a little better.
Had it Dyno Tuned after and was;
94.4 HP
106.7 Tourge.
