Lift and intake closing?
Old Jul 3, 2017 | 07:03 AM
prodrag1320's Avatar
prodrag1320
We use the S&S .583 cams in touring builds from 95" to 107",they work very well in heavy bikes
Old Jul 3, 2017 | 07:12 AM
CarlosGGodfrog's Avatar
CarlosGGodfrog
To the OP, what is your standard cruising RPM ? That will determine if you want a S&S 509/551/583 type cam or a high RPM (4500) cam. Also, what is your compression ratio ? IMHO, you should be looking for a torque curve that peaks at your cruising RPM, but I could be wrong.
Old Jul 3, 2017 | 10:54 AM
HDSAE60's Avatar
HDSAE60
My cruising RPM is 2800, and my CR is 10.2:1
Old Jul 3, 2017 | 03:22 PM
Arseclown's Avatar
Arseclown
s&s 570 is your cam then
Old Jul 3, 2017 | 04:01 PM
hrdtail78's Avatar
hrdtail78
It seems like cams with early intake closing all have low or stock lift, why can't I find a cam with a intake closing at 27 ABDC and .585 lift?
My guess would be something to do with early closing is for bottom/mid range. This goes along with valve overlap, duration and cam noise (aggressive lift)
Old Jul 9, 2017 | 02:37 AM
HDSAE60's Avatar
HDSAE60
Default My bad
I think my CR is more like 9.5:1. I have the cams out right now and will run a compression test without the cams in it and see what it really is.
Old Jul 9, 2017 | 03:21 AM
Hopper.'s Avatar
Hopper.
Because a higher lift cam needs longer to close the valve than a lower lift cam if you don't want it to be too noisy or slam the valve shut too hard. Basically, there's further for the valve to travel so it needs more time. Plus, at that quadrant, right down near BDC, a few degrees of crank travel does not translate to a lot of piston movement so it does not make a huge difference to working compression etc to let it stay partially open a few degrees more. Live everthing in engine building, it's all compromises.
Old Jul 9, 2017 | 03:30 AM
bklynbob's Avatar
bklynbob
You would probably like a CR 570-2 at 9.5. A 31 tooth pulley and a real dyno tune would do it
Old Jul 9, 2017 | 02:32 PM
Max Headflow's Avatar
Max Headflow
Not a good way to measure compression.. Need the valves working.. Can do a leak test tho..
Old Jul 9, 2017 | 04:34 PM
HDSAE60's Avatar
HDSAE60
I want to measure Static Compression, then with the cams in look at dynamic compression.
