engine knocking
Old Aug 10, 2017 | 04:18 AM
Gabe FXR's Avatar
Gabe FXR
1st Gear
Default engine knocking
good morning all, i have a 1986 FXRP and a few days ago it started knocking somewhere around the rear cylinder. I did a compression test and there's a 25 PSI difference between the 2 cylinders. the troobleshooting i did so far is a compression test, checked the oil to see if there was gas in it ( i couldn't smell any) The engine is not smoking black or anything and it starts and run really well. the knocking is constant and goes up with the rpm. I have adjustable pushrods in it and it's the last thing i have to check. Any other idea what could cause this if the rods are ok???? thanks.
Old Aug 10, 2017 | 10:29 AM
Max Headflow's Avatar
Max Headflow
With a 25 psi difference between the cylinders I'd say the top end need to come off. I'd check the front motor mount and make sure the drive train is not hitting the frame around the side stand and bottom rear cross over.
Did you try a squirt of oil in the cylinders and compression again?
Old Aug 11, 2017 | 06:09 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
I'd start in the cam chest........dollars to donuts that you have a failed lifter roller, probably harmed the cam lode as well.
Experienced guestimation.
Scott
Old Aug 11, 2017 | 09:41 AM
Max Headflow
Scott
This is likely a better guess..
Old Aug 11, 2017 | 10:05 AM
Hillsidecycle.com
Sponsor
Truth be known Bruce, the ONLY thing that I am sure of anymore, is that Jeremiah, was, a bullfrog.......
Scott
Old Aug 12, 2017 | 10:21 PM
Uncle Fuzzy's Avatar
Uncle Fuzzy
Scott
He was a good friend of mine....
Old Aug 13, 2017 | 06:45 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Do you have adjustable pushrods? if so check for a loose one possibly on the intake side of the cylinder with lower comp.... Also check that same lifter possibly collapsed..
Daedalus
EVO
42
May 15, 2018 01:38 PM
emtjester
Engine Mechanical Topics
Jun 16, 2015 07:46 PM
brawner11
Apr 7, 2014 07:43 PM
B88
Feb 3, 2010 09:31 PM
da_king96
Exhaust System Topics
May 10, 2006 01:39 PM
