o2 sensor volts
Old Sep 7, 2017 | 06:03 PM
rsking45's Avatar
rsking45
Default o2 sensor volts
Iv noticed the volt reading for the o2 sensors on my power vision are quite different between the front and rear o2. While the front stays pretty consistent .88+- volts, while the rear o2 volts are all over the place from .88 to .10 back and forth.
Is this a indication that I might have a o2 going bad?
Bike runs really good,Im getting 40 mpg, mpg not a big deal. I did Andrews 48 cams and had it dynoed last year when I had the pro pipe on it. Now I have a D&D exhaust on it.
Old Sep 9, 2017 | 09:12 PM
bustert's Avatar
bustert
the high number means the front is rich. the o2 should swing but the average should be .6 or so. if the sensor is locked, it is bad. front and rear will be diff, look at how the inlet is charged.
gtwalker1969
Apr 13, 2018 09:09 AM
AllenW
Aug 19, 2016 03:11 PM
hdkev
Aug 12, 2014 12:41 AM
kamkam2
Jan 25, 2013 05:50 AM
AZ RKC
Jan 7, 2008 12:05 PM
