Why no mechanical solutions for the cam tensioners and oil pump?
Old Oct 17, 2017 | 12:50 PM
QNman's Avatar
QNman
I thought "wear" and "brake" were different..
Of course!
Old Oct 17, 2017 | 02:24 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Originally Posted by QNman
I'm sorry, what now? As long as moving parts are contacting one another at a rate of thousands of times per minute, wear will NOT stop. What kind of engineer did you say you were?
Ooooh... sorry, a self-appointed know-it-all... my mistake.
ETA: And the hydraulics weren't a "smoke screen"; they were a superior and equal way to apply pressure compared to a spring.
What you fail to see is I am referring to the roller chain models. Your statement is true for the total link chain. It always rubs and wears. In fact, at maximum RPM at the speed limiter, it's moving fast enough to cavitate the oil and blast hunks out of tensioners. The roller chain only has outer links and they groove in and the rollers roll. Tensioner will last the life of motor or 10 years or so when they get brittle and can crack from hot oil embrittlement of the delrin.
You are correct that there is wear even with the roller rolling. However, it is almost unmeasurable other than the outer groove. Shoes in cars are hard rubber and last longer than the roller chains.
The first attachment is 90K on a roller chain. Second is 45K on a link. And third is Harley so-called upgrade which leaves the back chain link.
Old Oct 17, 2017 | 02:47 PM
Super Glidester's Avatar
Super Glidester
Originally Posted by Scottyxbones
From what I've heard, the gear drives only work if a crankshaft has a minimal run out, .003", but factory spec is +-.012". I was talking about using the spring or hydraulic cct, but instead of a plastic shoe pressing on the chain, use a wheel so the friction would be insignificant.
Good to know there's an aftermarket oil pump with a screen out there, thanks I'll look into it
And I appreciate the explanation of why the cct' s failed to begin with, extra pressure. I've read the advice to check the wear on the shoe every 15k-20k mi, how much mileage can I expect to get from a hydraulic cct before I should check for wear?
P
Patent the idea , then invent it.
Old Oct 17, 2017 | 03:35 PM
yooperbigdog's Avatar
yooperbigdog
Ripsaw-good pics and info, wish you lived close to me as it seem's your real handy at changing tensioner pads out ?????
Old Oct 17, 2017 | 04:29 PM
Max Headflow's Avatar
Max Headflow
The idea that the oil is cavitating is very interesting.. It would explain the divots. I figured the tensioner was slapping the chain and causing micro fractures but the possibility of cavitation explains a lot. My bet it's a combination of spring pressure and silent chain construction that creates small chambers at the link where oil could cavitate..
I don think that the shoe is delrin. The delrin can't handle the temps. I figure it's some form of Ultem and probably not PEEK.
I don't think the inner hydraulic tensioner failure was the result of the silent chain from it's surface configuration but could be from the poor tolerances in manufacture. Chain may have had a tight spot. More than likely the hydraulic part tensioner failed as the same type of failure has been documented on roller chains.
One thing to remember is that autos are liquid / fan cooled so temps cam be controlled better. They probably don't see much above 240F.
Old Oct 17, 2017 | 04:31 PM
QNman's Avatar
QNman
You're right, I must not understand... What are you calling a "total link chain"? A "roller chain" is what they use; a "roller chain", as I understand it, refers to a type of chain drive that is used on chain sprockets - just like every chain ON a Harley. If you could please explain the difference you are talking about, I'd be much obliged.
Old Oct 17, 2017 | 04:34 PM
QNman's Avatar
QNman
Can the shoes wear out? Of course, they can. Do some wear out prematurely? Of course they do. Does this happen because of some cheapskate, conspiracy, customer-hating evil corporate-level hacks?
No.
(Not aimed at you, headlfow).
Old Oct 17, 2017 | 04:57 PM
Jackie Paper
Think the link chain is referred to as a silent chain. First TC and up to around 2007 or 2008. After that, roller chain. Which is a roller spinning on an axle. Harley's part is cast in my opinion delrin. I worked in heat treating as part of my toolmaker apprenticeship years ago and we heat-treated delrin for special applications for periscope mask bearings slides. Delrin can take oil heat.
Old Oct 17, 2017 | 10:34 PM
Breakout110's Avatar
Breakout110
Bandaids....
Get the crank done and go gear drive.
Old Oct 19, 2017 | 06:30 PM
xcbullet's Avatar
xcbullet
If a cooler is added to bike and the SE plate is set up with cam gears .001 inch it will last. This is on the silent on my bike , 30,000 miles later could not see any wear on the edge. Had cyco pads ready to go in but looks like the white SE pads will out last this build.
