103 se build
Old Oct 30, 2017 | 10:47 PM
jimmmya's Avatar
jimmmya
Default 103 se build
HI, we just finished a build on a 2016 RGS 103 ci we used a HD # 92500005 stage 4 SE
CNC ported Factory cylinder heads
10.5 to 1 forged pistons
SE-259E cams
pushrods
58mm throttle body
Hi flow injectors
New cylinders
It was installed by a very knowledgeable and professional builder we have not started it up yet. In the injector box there was a WARNING saying DO NOT start up UNTIL the ECM is re calibrated by the dealer or damage to engine and ACRs will result.
I am now running a FP3 and have a SE Tuner came with the kit
Can I start the bike without hurting the ACRs or engine I believe there worried about fuel management more the hurting the ACRs
I'm looking just to break new engine parts and send to dyno with Dynos choice of tuners thanks
Old Oct 31, 2017 | 04:48 AM
TomCop's Avatar
TomCop
If it is done by a professional builder then the correct mapping should already been uploaded onto the ECM. And as a matter of fact he should already have started the engine. I assume he or she did a compression test as well.
If the above is done, start your engine.
If not, you will need to select the mapping closest to your configuration and upload it.
And start your engine.
Then off to the dyno for the actual tuning.
Success!
Old Oct 31, 2017 | 06:34 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
It'll start and run on the OEM map.
If in Rhode Island, RAW Motorsports in Swansea, Mass, should be able to tune that.
Scott
jimmmya
The Dyno Room
Oct 31, 2017 08:10 PM
4srco2
Jun 26, 2017 09:12 PM
Big Twi$t
Dec 11, 2009 08:50 AM
Papamte
Aug 18, 2008 08:53 AM
WISHBONE
Exhaust System Topics
Feb 12, 2007 10:36 AM
