Branch-O'Keefe Heads
Old Nov 16, 2018 | 09:55 PM
Jerrysounds's Avatar
Jerrysounds
I have an 80in Evo with the "Old" Branch O'Keefe technology heads and it hits 98hp and 103ft pounds of torque with a 10.25 to 1 compression. I have put 10k on the bike without any real issues. The bike is surprisingly fast for a 575 lb bike. I say if you know how to build a motor, you can make that old tech of Branch O'Keefe work well.
Old Nov 17, 2018 | 06:12 PM
PWMORRIS's Avatar
PWMORRIS
Time to move on...step up and get your heads done by someone who actually knows modern TC head profiles (HD & S&S), has an outstanding rep doing them, and delivering PROVEN, DOCUMENTED HP. Period.
You can count that list on both hands.
Old Nov 19, 2018 | 06:12 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Our heads, once ported, are completed on our Winnona-Van Norman PH2000 Seat & Guide Machine, using Serdi/Mondello/Goodson tooling, with 4-5 angle seat form cutters, centering from carbide pilots, and then checked on our SuperFlow 600 flow bench.
Installed heights within .002" from one another is the norm, and when performing work on the M8 heads, is ABSOLUTELY critical, and then, each valve is hand-lapped to insure spot-on sealing.
Scott
Rat1
Exhaust System Topics
22
Feb 27, 2011 04:17 PM
speedracer
Jan 25, 2011 07:02 AM
devilfishlane
11
Jan 19, 2011 01:17 PM
fiddledicksr
Apr 20, 2007 01:47 PM
wnogood
Aug 25, 2006 11:00 PM
