Twin Cam motor removal
Old Nov 17, 2017 | 07:47 AM
rigidthumper's Avatar
rigidthumper
Take the few extra minutes to remove the oil tank and thoroughly clean it, ( or replace it with a late model tank- they are not that expensive) and replace all rubber lines. You don't want some left over piece of pump ruining your new build.
Old Nov 17, 2017 | 10:27 AM
hrdtail78's Avatar
hrdtail78
The time to do that is definitely when the engine is out. I hang the trans with top mounting holes and a ratchet strap over the frame. (under wire harness)
Old Nov 17, 2017 | 01:01 PM
Campy Roadie's Avatar
Campy Roadie
Like the pic above
Old Nov 17, 2017 | 02:05 PM
Max Headflow's Avatar
Max Headflow
There ain't any way I'm pulling pulling a motor out without a hoist... I put the bike on the side stand and use an engine hoist.. I don't use the strap method but slide a small wood scarp under the tranny at the motor mounts and let it rest on the frame.. No straps to mess with..
Old Nov 17, 2017 | 03:57 PM
Campy Roadie
There's no way I could get one out of the frame without a hoist either. The wood under the tranny across the frame rails is a good idea for sure. The strap helped me on re-install because I could raise and lower the trans to align the dowel pins between the engine and trans and not mess up the gasket in between.
Old Nov 17, 2017 | 04:37 PM
Johnk1173's Avatar
Johnk1173
Last couple of R&R flywheels I dealt with had very light press on crank pin. S&S over size pin was my fix. Ate the cost with no help from a business that should of stood behind their work.
R&R presses and welds the crank, did they not do that to yours? Curious, as they just did a new crank for me...
Old Nov 17, 2017 | 04:43 PM
Johnk1173's Avatar
Johnk1173
I used the strap on install for the same reason
Old Nov 17, 2017 | 05:59 PM
Max Headflow
I'm sure it was welded.. Welds really done do much other than crack..
Old Nov 17, 2017 | 06:22 PM
AtticusFinch's Avatar
AtticusFinch
Before I removed my engine last month the most complex tasks I had undertaken on my Harleys were installing Big Radius exhaust on my Dyna and changing out the handlebars and slip ons on my Road King. I followed the service manual meticulously. I searched YouTube for videos when I wasn't sure about the instruction in the manual. I asked questions here when that failed. It's definitely a doable project for a novice.
I did chicken out when it came time to reinstall the engine. Mostly because I was anxious to ride it this fall before the few remaining days disappeared and I had a lot to do at work. I went with the S&S 124" motor. Loving it so far! It really wasn't much more expensive than a big bore plus the crank work you're contemplating. There are less expensive options though, including installing a take-off low mileage 103".
Good luck and have fun!
Old Nov 17, 2017 | 07:08 PM
Max Headflow
