Checking valves
Old Nov 19, 2017 | 12:15 PM
Clayton24's Avatar
Clayton24
Default Checking valves
What is the best way to check valves for sealing before instaling the heads ? Thanks !
Old Nov 19, 2017 | 12:20 PM
TwiZted Biker's Avatar
TwiZted Biker
Turn them upside down with the valve faces pointing up and the head leveled and pour a little alcohol on them then watch to see if any seeps into the port's. Old school trick.
Old Nov 19, 2017 | 09:58 PM
Clayton24's Avatar
Clayton24
so as long as nothin leaks through after i lapped them im good ?
Old Nov 20, 2017 | 06:36 PM
marcodarq's Avatar
marcodarq
while the fluid test is usually pretty good, your machinist can pressure test them for you if you feel the need,,,,,most home shops don't have the stuff for it, but it wouldn
't cost much either.
m
djs
Milwaukee Eight (M8)
32
Nov 27, 2021 05:30 PM
hdrider53
Exhaust System Topics
Nov 10, 2021 07:27 AM
Ironyman
Ironhead
Oct 18, 2014 02:55 PM
Rtlang
Shovelhead
Feb 16, 2014 05:31 PM
customsleds
Jul 13, 2006 03:07 AM
