Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
soooooo many factors. it stands to reason that less recip weight will get to speed quicker. another is stroke as the shorter distance to move is quicker.
Lets see, High flowing heads, big cam, Bigger T-body and injectors, hi compression pistons, good ignition, good 2-1 pipe, Port match intake, 3.37 gear ratio.
Or should I have said a phone call and about $3-4k. Kirby or Scott, Wide open Cycle. Theres a lot of good guys out there.
Without changing the flywheel mass the quicker reving motor will be the one with higher cold cranking compression and a good tune and pipe.. Bigger displacement will help as you can only generate so much pressure without detonation. Bigger displacement will generate more force on the flywheel at the same pressure so it will spin up faster.
ive been wonderin how much ccp one can get away with on a wet head ! I always ride one up !
what is a real quik reving engine combination say 103-110 cu in? Thanks for all replies and info !
Your 57 cams, 110" S&S kit, 10.2 cr, a set of our HMM Stage II Heads, and your t/body modified, with a 2/1 D&D Fatcat.
It'll come on VERY quickly.
Scott
