Newbie cam question..
Old Mar 4, 2018 | 04:03 AM
sliazafoxx35's Avatar
sliazafoxx35
Default Newbie cam question..
I have a 2015 rgs with Rinehart 4" slipons, v&h dresser duals, s&s a/c, and a fuelpak 3 in my 103...looking for a little more low and midrange (2000-4000rpm)...my question is can I upgrade my cams and use the fuelpak or do i need a tune and dyno
Old Mar 4, 2018 | 08:51 AM
bustert's Avatar
bustert
so you want some more oooph in that range? try a gearing change be it primary or secondary.
old saying, "if you change one thing, probably have to change something else"! engine must be a system of well playing parts.
Old Mar 4, 2018 | 10:23 AM
GalvTexGuy's Avatar
GalvTexGuy
Yes, you can use the FP3. They have over 50 aftermarket camshafts incorporated in the View/Edit Maps area. After choosing the cam, they suggest running an AutoTune session.
Edit: If the cam is not listed, you can always call and they'll manually modify your map for you. Of, course, nothing beats a good dyno done by a competent dyno operator.
Old Mar 4, 2018 | 12:48 PM
sliazafoxx35
Thanks! So choosing a cam is pretty nuch hit or miss with that many choices...alot if people go woods or andrews...i was looking at tge s&s 585...anybody got recommendatiins...im 265lbs and like to ride 2 up
Old Mar 4, 2018 | 03:32 PM
Arseclown's Avatar
Arseclown
​​​​​​Im not being a smart **** but I think you need to learn about cams. There's a good sticky topic that'll help with what info means what. The S&s 585 cam is not suitable at all for your bike and what you want. Look at cams with an earlier intake close. Hard to beat the cyclerama 570 for a stage 1 Tourer for what you want. Good luck
Old Mar 4, 2018 | 03:39 PM
cdonis's Avatar
cdonis
If you want a great answer from a builder up in NY, call Scott at hillside cycle. Jmo, 585.....no, and fp3 no. Wrong cam for what want. There are better choices, then dyno tune it after the install. Chances are the tuner will not want to use the fp3 unless you insist.
Old Mar 4, 2018 | 03:49 PM
Bafflingbs's Avatar
Bafflingbs
If trying to stay on a budget, Andrews 48's if looking for the biggest gaines, Cyclerama 570-2
Old Mar 4, 2018 | 04:22 PM
djl's Avatar
djl
Andrews 48 will achieve the OPs goal. The FP3 is no substituted for a proper dyno tune but plenty of FP3 guys have been happy with what they can do with the FP3 and the V&H tech support is said to be excellent. Tune with the FP3 first and if the OP isn't satisfied, he can always head to the dyno.
Old Mar 4, 2018 | 09:15 PM
darkcustom7's Avatar
darkcustom7
im running Andrews 57H in my 13 SG and i love them.
Old Mar 5, 2018 | 05:58 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
An Andrews 48 will work well, as a CR .570 also.
Those FP3 units will not deliver anything like a dyno tune, but should work ok.
Scott
