Looking for advice on my new build
Old 03-19-2018, 06:01 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Hillsidecycle.com is offline
Sponsor
Should run fairly well.
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Old 03-23-2018, 01:37 PM
djl's Avatar
djl
djl is offline
Received 2,048 Likes on 1,509 Posts
Not much different from what 98hotrodfatboy posted but I don't think reducing chamber volume is necessary. Mock up the top end and check deck height; I suspect it will not be 0.00" and the pistons will be down in the bore .005"-.007" which is why S&S posts 10.1:1 as static CR. I am betting that the OP can set deck at 0.00", replace the .045" head gasket with a .030" gasket and CCP will pump about 195-197psi; good enough for the 585 cams.
Moot points but perhaps the OP could exchange for different S&S parts, i.e., exchange the 107" kit or pistons/cylinders for the 4" kit for 110"; picking up 3" at no additional cost is worth consideration IMHO.
If the T/B is cable operated, consider having the OEM 46mm T/B bored to 50mm. Dan Vance offers this service and I think Scott/Hillside does as well. If the OP had gone the bore OEM to 107" route in lieu of the kit, the money saved would have paid for the throttle boring.
Vasilis
Engine Mechanical Topics
10-18-2016 12:20 PM
SoCaFLHT
05-16-2016 08:31 PM
scottnumero2
03-26-2011 01:37 AM
OldBoldPilot
02-07-2011 03:44 PM
VETERAN75
04-07-2010 03:22 AM
Quick Reply: Looking for advice on my new build
