Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Took my 2014 flhxs to a 110 this winter and thought would share.
S&S new liner 110 and adj push rods and lifters,wfolarry stage2+ heads,hpi 58 and hpi air cleaner.5.3 injectors cyclerama 595 cams 30 head gasket,rockout rocker ,primo clutch .
A Big Thank You to Darren at Sheffer Performance , a great example of customer service and Just a great Guy.Also high desert performance for an excellent tune Paul another example of man that loves his work.
