Breather bolt/cylinder head issue
I was installing my powdercoated rocker box covers today. I thought that I blew out all of the holes but I must have missed one. When I was torquing the breather bolts, the center bolt popped & pushed a small pieced of the bottom of the head. How screwed am I? Will it leak or is this not really an issue?
Hydraulic pressure is an amazing thing. Did not take much to do that. Is there an opening to inside now? Little gray or black Permetex gasket maker rtv on the threads will seal from top. Valve cover gasket seals around it.
What I used on the head bolt on my Jeep that goes into the water jacket. That is just to the valve cover, isn't it?
