Can the Average Joe install big bore kits?
Old Aug 22, 2018 | 01:59 PM
CndUltra95's Avatar
CndUltra95
Originally Posted by Studlintsean
I will speak form the other side of the table. I am nowhere near mechanically inclined. It took me an hour to change the damn headlight bulb to LED (plug and play) and I am now dealing with a stripped derby cover bolt after doing my first 3-hole fluid change. Plan on doing a throttle and clutch cable lube and fixing derby cover this weekend . I would say I am good at following directions but always seem to F something up. I figure you gotta start somewhere and I am hoping it becomes easier over time.
Good luck
Sounds like my luck, but then again I like to fix things till they break.
To the OP, spend some time on ewe toob and get the service manual for your bike.
Familiarize yourself with the electronic version (ewe toob) and the book and give it a whirl, you may end up pleasantly surprised.
A good set of basic wrenches an inch pound torque and a foot pound torque wrench will be invaluable and the bearing pullers for the cam(s) can be sourced via the swap section.
Maybe someone local who wrenches might chime in and offer up a lift and a learning event too.
Or ask around local who works on their bike who might assist for compensation within reason on working with you on your bike???
Save the six pack for after the work has been completed cause diving back in after several wobbly pops might not be a good option.
Rob
Old Aug 22, 2018 | 02:12 PM
sailmotion's Avatar
sailmotion
Originally Posted by ThePaintPirate
Really what this all comes down to, is that I'd like to be able to sit back, take a look at the 117 badge, and be able to say "I did that." Unfortunately, I'm not the only one who's had that mind set and then really fubar'ed the thing. I'm not looking to do it myself to save money, really it would be better to just throw money at a professional and not have to have that nagging voice in my head second guessing my install.
I hear what you're saying. It's comical the pride I take in showing off the gas cap cover I replaced [remove and replace 2 screws] or the fairing lights I installed [drill a hole, plug & play the wiring and stick the strips to the fairing]. My next major accomplishment will be doing my own oil change. It will probably take 2-3 days just so I don't overfill on the first add.
Old Aug 22, 2018 | 04:48 PM
Z's Avatar
Z
Unless you're thinking that you''d like to make a hobby of DIY'ing your repairs and mods, and if money isn't an issue, I suggest you pay a pro to do it, and spend that time doing something that you love. One simple mistake could lead to big headaches, and one task performed that you didn't feel confident about could linger in your mind for thousands of riding miles.
Old Aug 23, 2018 | 10:49 AM
djl's Avatar
djl
It's a top end job that requires cam and T/B to be replaced. Quite doable even for the first timer so long as the first timer is patient, diligently follows instructions, understands that cleanliness is very important, has the proper tools and service manual and understands that Murphy is ever present. Read the applicable sections of the service manual several times while familiarizing yourself with the various components that must be removed and replaced. Before starting, get organized, i.e., tools, new parts, etc. Know how you will organize all the nuts, bolts and OEM parts that will have to be reinstalled with the new kit; bag and tag if necessary to avoid mixing up or losing stuff. Study the procedure so you will know and can order the bits and pieces, i.e., gaskets, o-rings, thread locker, etc. that may not be included in the kit so you have them on hand.
Having said all that but stepping back a bi, I would ask the OP what his goal is and whether or not the goal can be achieved another way? I am thinking that with a good set of ported heads, matched up with a new set of .010" over CP pistons to establish a true cylinder bore, the SE 58mm throttle body and a new cam set, the OP can achieve the same goal for the same, perhaps even, less money particularly since the OP is considering taking on the project himself. Of course, there is no 117 badge to display by going that route. We have two forum sponsors could provide the machine work as well as help the OP with cam selection for a set of parts that play well together. The HD 117 kit might make 115/115 numbers but going the other route, the 110 rebuild could easily make 120/125 numbers.
As for paying a professional, that has not always worked out for some forum members. I am fortunate to have two true professionals in my orbit should I ever decide to let someone else work on either of my bikes but all of us are not that fortunate. Before the OP makes that decision, he must be absolutely sure that the professional is a true professional that can guide the OP in making good decisions and that will stand behind his work. To summarize and JMHO, pass on the HD kit, develop a build plan with one of our forum sponsors, identify a competent tuner (hopefully near by) and plan to DIY the project.
The OP did not mention addressing the bottom end, exhaust or fuel management; all important and should not be overlooked int the overall plan.
Old Aug 23, 2018 | 02:07 PM
QNman's Avatar
QNman
I'd say if you are mechanically inclined, yes, you can certainly do it yourself. Take your time, be organized, follow the instructions, and have your torque wrench handy. If the manual specifies a torque, use the torque wrench. Don't improvise - follow the steps in order. Have a friend or other mechanically inclined person on call in case you get stuck. Stay sober (ish) while doing the work. Don't try to do an "all-nighter"; take breaks, etc.
If all of that sounds like too much worry, I'd just pay someone. I've done all this myself many years ago, and honestly, now I can afford to pay someone else to do it, and I spend my time pursuing other hobbies rather than weekends on the lift.
Old Aug 24, 2018 | 01:25 PM
GaryLC's Avatar
GaryLC
I say go for it. The personal satisfaction of having done it yourself is a great thing. These engines are really pretty simple machines once you get into them. If you can read a service manual and follow directions you can do the job. Build it and have fun with it.
Old Aug 24, 2018 | 01:36 PM
RET_SCPO's Avatar
RET_SCPO
I've always been a do it myself kind of guy but a job like this is worth paying the shop to do just for the warranty and peace of mind in knowing that if they make a mistake it's on them and not you. An older bike sure why not, but now on a newer machine that costs a lot of money.
Just my .02.
Old Aug 26, 2018 | 09:01 PM
hetkehog's Avatar
hetkehog
I just did mine the number one thing was clean and organized. Which I did. The other thing was only do it by yourself. Lock the shop door behind you. No help. It will turn out. Take your time. Be patient that's my .02
Old Aug 27, 2018 | 03:56 AM
Campy Roadie's Avatar
Campy Roadie
Originally Posted by rigidthumper
The only downside is not being aware when something is amiss- like my friend who caused case damage when he used the cam cover bolts in the cam plate. Easy mistake, as they are only 1/4" longer- and he just thought the loctite was causing it to be tight going in, so he torqued it to spec...
And dented the lifter bores.
I'm with DJL. There just isn't any "kit" from HD I'm interested in. Any boring I have done is completed by someone who knows what they're doing and they have the pistons (good ones) in their hand. They're also going to port the heads for desired outcome. If it has to come apart, I leave no stone unturned.
Old Aug 27, 2018 | 09:29 AM
ThePaintPirate's Avatar
ThePaintPirate
In the cornfields of Iowa, there are very few resources besides dealers to get the job done, we don't have options like the big city folk do. There's one performance shop near Des Moines that another forum member has used with good results. I've thought about just sending my heads into FuelMoto and having them machined, but while the turnaround time is 2 weeks, with a downed bike you might as well just do the kit, and then it turns into an "if you give a mouse a cookie" situation. Bike currently has Cobra 2-1 exhaust and Power Vison tuner.
Just my .02.
And that's the main reason I'm considering having a shop do it.
