New Build FM 107 break in Oil Pressure on start up
Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
After 8 Mile ride in 50 degree weather 2500-3500 all is good
Pressure under load 31 to 35 PSI
once engine got up to warmer temp, 194 coolant , 208 ET then oil pressure was 15 PSI at idle
My '12 Limited got hot enough in multi level parking traffic in Vegas to shut down where I had to let it cool off a bit. The wethead I have now seems to regulate itself just fine, even during extended idling.
