Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Will I notice any power increase if I install a new cam (thinking Andrews EV27's) and Pushrods on an 88 stock Evo?
No head work or pistons, just the cam and rods.
It's a 94 Softail Custom, V&H Big Shot Staggered and high flow Air Cleaner.
And I'm doing a S&S ignition module with a dual fire coil.
The pushrods mean nothing. they have a job to do.
You are limited in the cam dept by stock CR value so you will probably need a bolt in. (as you stated )
Yes, you will realize more pwr.
There is more almost free pwr there just by decking the virgin heads.
It becomes a slippery slope and I am **** over teakettle.
I put a EV 3010 in my 99 fatboy which I read is an almost exact copy of the 27 an it was like a different bike. First test ride I bounced it off the rev limiter twice it reved so much more quickly. It's def worth the effort.
I realize you are looking for feedback from someone with a similar build, but another option you might try is calling or emailing Andrew Products with your question. The few times I've contacted them, I thought their tech support was very good.
Yes, you will feel a noticable difference. My brother has a similar bike, 97 Heritage, high flow A/C, 2 into 1 exhust, ignition and a EV27 cam, he did not pull top end. Even with the stock compression and no headwork the cam works well.
