MCR Install
Old Jan 10, 2019 | 02:30 PM
23Seven's Avatar
23Seven
Default MCR Install
Pricing Manual Compression Releases.
I looked at Big Boyz and they are $40 for machining and $40 for releases. I have to deal with downtime while shipping back and forth.
Local Shop $290 if I pull the heads, $690 if they pull them.
Does anyone know of a machine shop somewhere around the San Francisco Bay Area that does good work?
...or does anyone rent out Jim’s tool so I can just drill them out myself?
If I had someone local that could do it for Big Boyz price that would be great.
Old Jan 10, 2019 | 07:22 PM
Big Dave's Avatar
Big Dave
I have the same motor 48 cams etc , are you having starting problems or looking to the future mine seems to spin just fine
Nice bike and its been fun watching your build , 48.s really woke up my Ultra love that cam
Dave
Old Jan 10, 2019 | 08:43 PM
23Seven's Avatar
23Seven
It starts a little slow mostly when hot and kick back every once in a while.
New battery and it stays on the tender.
The other part is I kinda want to put the .030 Gasket on and bump up the compression a tad.
Old Jan 11, 2019 | 06:21 AM
Mattbastard's Avatar
Mattbastard
You're on the right track. I personally believe anything more than 88" is too much on any HD starter (within typical compression values, of course). When I built my dad's 95" it was 9.5:1 with stock heads and flat tops with a brand new battery and all connections between starter and battery and it still cranked slowly. S&S EZ-Start cams made quick work of the issue though.
Old Jan 11, 2019 | 10:41 AM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
You could give Jim @ Metal Dragon in Hayward a call and see if he can help you out. 510-885-9471
Old Jan 11, 2019 | 10:46 AM
cdonis's Avatar
cdonis
re engineering
Old Jan 11, 2019 | 12:41 PM
CarlosGGodfrog's Avatar
CarlosGGodfrog
Does anyone make a lever to attach to the MCR button ? Don't like burning my fingers on a hot restart.
Old Jan 11, 2019 | 01:01 PM
Jake707's Avatar
Jake707
$290 if you bring the heads in sounds crazy. It should be right in line with those prices you got for Big Boyz at any real shop. There's a local shop in Vacaville but that would be a 45 min stretch for you. Try RC cycles in Hayward.
The releases themselves are usually $30-$50 a piece depending on what kind you get. You can shop around online and get them even cheaper. I would recommend those with the plastic cap, usually offered in any color. I had a friend all about chrome go with chrome cap ones and those are what burn the sh*t out of your finger on a long day of riding.
As for the machining it its quick and easy for them and I think the going rate around here is $40 a pop.
Old Jan 11, 2019 | 01:53 PM
LQQK_OUT's Avatar
LQQK_OUT
For $290, you could purchase the HD Screamin' Eagle Mechanical Compression Release Machining Fixture and do it yourself.
HD Part Number: 94638-08
https://serviceinfo.harley-davidson....ght%3D94638-08
Old Jan 11, 2019 | 03:03 PM
Tat2u's Avatar
Tat2u
I’ve never burnt my fingers.. Shouldn’t really happen, especially when wearing gloves
