MCR Install
Old Jan 11, 2019 | 03:50 PM
23Seven's Avatar
23Seven
Originally Posted by Jake707
$290 if you bring the heads in sounds crazy. It should be right in line with those prices you got for Big Boyz at any real shop. There's a local shop in Vacaville but that would be a 45 min stretch for you. Try RC cycles in Hayward.
The releases themselves are usually $30-$50 a piece depending on what kind you get. You can shop around online and get them even cheaper. I would recommend those with the plastic cap, usually offered in any color. I had a friend all about chrome go with chrome cap ones and those are what burn the sh*t out of your finger on a long day of riding.
As for the machining it its quick and easy for them and I think the going rate around here is $40 a pop.
$290 was from RC... So far talked to Livermore H-D, RC Cycles and HK Cycles. Everyone wants $200 to drill.
Old Jan 14, 2019 | 11:14 PM
Bluehighways's Avatar
Bluehighways
Amazon has the entire Jims C.R. Tool Set for $330.00.
Search for "JIM1169"
Get a Digital Vernier Caliper from Harbor Freight for $15.91 ($18.99 - 20% Coupon) borrow a Drill from a friend and you'll be all set.
This job is NOT rocket science and when you're done I'm pretty sure you'll be able to resell the Tool Set for at least 50% of what you paid for it.
I've even attached a 20% HF Discount Coupon for your use!
Old Jan 16, 2019 | 06:17 PM
Max Headflow's Avatar
Max Headflow
Now that's funny..
Old Jan 27, 2019 | 05:04 AM
lionsm13's Avatar
lionsm13
Fuel moto
;https://www.fuelmotousa.com/i-238519...d-porting.html
Level B CNC Cylinder Head Porting - $879.00
Available for both air cooled and twin cooled H-D models, the Fuel Moto Level B CNC cylinder head is our premium street performance head. It was developed over hundreds of dyno runs with a wide range of combinations for best overall performance gains, it works especially well with 103" and 107" builds and makes exceptionally broad torque along with high RPM horsepower. Our new CNC ported head offers unmatched consistency and accuracy.
Fuel Moto Level B CNC includes the following:
  • Complete disassembly, inspection, and cleaning of cylinder heads
  • Extensive CNC porting, texturing, and blending with an emphasis on best all around performance
  • Oversize Stainless 1.900" Intake 1.610" Exhaust valves
  • Newen Contour-BB CNC valve job
  • Our beehive style valve springs are manufactured from ultra clean high silicon / vanadium Kobe alloy wire and are certified up to .600 lift
  • CC combustion chamber, set to desired spec
  • Machine/Install compression releases if required (+$100.00)
  • Exchange with core charge or 2 week turnaround on customer supplied heads
lowriderr9
Jul 13, 2019 12:10 PM
magnum629c
Nov 29, 2018 09:15 AM
Skip
Exhaust System Topics
Apr 13, 2013 09:29 AM
buckey64
Dec 10, 2010 10:19 PM
Tltrump
Dec 28, 2008 06:41 PM
