Planned build, any good? Reliable?
Old Jan 23, 2019 | 08:19 AM
motorcycleboy's Avatar
motorcycleboy
Default Planned build, any good? Reliable?
I have a ‘14 Limited (wet heads obv.) with 30k miles. I’m looking at doing the S+S 110 kit, which comes with the oil pump and cam plate, and uses the 585 easy start. I’d also like to send the heads to Cyclerama, for some of their magic, and haven’t decided how to beef up the clutch.
my questions:
can I get away with the stock throttle body for now (reaching the extent of my budget)?
will the 585 cam work well with headwork?
how reliable are builds like this?
thanks for your thoughts
Old Jan 23, 2019 | 09:58 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
AIM lock-up hat will handle the clutch chores, and an S&S .570 would whip the torque up MUCH sooner than the .585, which is paramount in a heavier bike.
110"/.570 evidence can be seen on our company Facebook.
Scott
Old Jan 23, 2019 | 10:19 AM
motorcycleboy
Thank You!
I will check out those parts, and your page.
Old Jan 23, 2019 | 10:58 AM
djl's Avatar
djl
If Cyclerama is doing the the headwork, why not talk to Wes about one of his cams to go along with it. Not throwing shade at S&S, just sayin? CR cams are putting up some nice numbers.
Old Jan 23, 2019 | 03:37 PM
motorcycleboy
Only because 1. I like the easy starts. And 2. The S+S cam would come with their BB kit.
If I part things out more, I will definitely consider his cams.
Old Jan 24, 2019 | 05:24 AM
Slingshot383's Avatar
Slingshot383
The Screamin Eagle heavy spring and clutch disc's work good also, you will notice the stronger pull on the clutch lever.
Old Jan 24, 2019 | 07:02 AM
Yo_Boss's Avatar
Yo_Boss
The S&S 585 cam is a dog on the bottom. You won’t like it in that bike, listen to Scott.
Old Jan 24, 2019 | 11:48 AM
Tat2u's Avatar
Tat2u
It's not a dog if the compression is set right but I do agree it's more a mid to high rpm cam, not the best choice for a tourer.
SE Heavy duty spring + the AIM VPC is the go for your clutch upgrade.
Wouldn't your bike have ACR's?
Old Jan 24, 2019 | 12:49 PM
motorcycleboy
Thank you everyone- seeing consistent opinions on the 585, ok. And I’ve scrolled through some of Scott’s dyno sheets from builds using the 570- WOW at the flat torque curves!
And yes, I do have ACR’s, but those EZ starts are sooo light, I had 551’s in an old, stock, Ultra, started and ran beautifully.
Any thoughts on the reliability of these builds? Some people tell me you have to keep them stock or I’ll be running into constant problems, but if most of the parts are an upgrade over stock, and it’s built correctly, I find that hard to believe.
Old Jan 24, 2019 | 01:59 PM
Hillsidecycle.com
Sponsor
Not like an A.I.M lock-up hat.
A well-built 110", will need one. 95LT.
Scott
