Torque specs
Old Feb 10, 2019 | 06:25 PM
Hdnut1982's Avatar
Hdnut1982
Stage II
Default Torque specs
Torque specs for cam support plate on an 06 FLHX
Old Feb 10, 2019 | 07:34 PM
ntraindavefl's Avatar
ntraindavefl
100-120 in/lbs
Old Feb 10, 2019 | 07:40 PM
Hdnut1982's Avatar
Hdnut1982
Stage II
Default Torque spec
thanks brother
Old Feb 10, 2019 | 09:22 PM
Screamin beagle's Avatar
Screamin beagle
There's a sequence to that as well...and for realigning the oil pump.
Old Feb 11, 2019 | 04:09 AM
Ridetothehill's Avatar
Ridetothehill
Does it matter how the gearoter goes together? Does it need to be indexed somehow? When removing the oil pump, it came out in my hand. I put it back together. I will check the manual; but, I thought you might know. Thank you
Old Feb 11, 2019 | 11:26 AM
djl's Avatar
djl
Yes, it does. Scavenge gerotor first, separator plate, spring plate, separator plate and supply/pressure gerotor. Do you have the service manual? Should be the first thing to have before starting work. If not sure, check Ronnies Parts Finder for the parts diagram.
Old Feb 11, 2019 | 11:57 AM
Jake707's Avatar
Jake707
YES it does! Put them in wrong and you wont build oil pressure and will burn **** up real quick. Get a parts manual that has exploded views of everything or at least find the diagram online somewhere and confirm yours is right before closing it all up. Also make sure to follow sequence as said above it aligns the pump.
Old Feb 11, 2019 | 04:13 PM
Ridetothehill
Thank you. Yes I have a manual, so I'm not sure why I asked. Iv'e been away from this for a long time. It's all starting to come back to me now. I thought I remembered that there was an order to the pump assy. I guess I just asked to remind myself to look in the manual. Also, thanks for the reminder to use exploded view in parts catalog.
thisidworks
Touring Parts
Jan 18, 2018 03:41 PM
displacedcajun67
2014-2024 Touring Models
Jul 11, 2017 06:41 PM
galaxyfe
Engine Mechanical Topics
Aug 22, 2015 07:33 PM
car5car
Exhaust System Topics
76
Dec 29, 2009 12:20 PM
maddogkiller
Feb 3, 2008 09:11 AM
