Beatbox valve springs for 259e?
Old Mar 28, 2019 | 05:41 AM
Nickd2689's Avatar
Nickd2689
Default Upgrade valve springs for 259e?
Lol title is supposed to say “upgrade”, not beatbox
For those who are more knowledgeable than myself in regards to valvetrain, I’m curious what the best valve springs would be for 259e cams? I believe max lift is .579. I don’t want to end up causing additional wear but don’t exactly trust the stockers either. I’m also looking to do guides/valves/etc while I have the heads off. It’s worth mentioning that I do beat the hell out of the bike....
17 lrs with screaming eagle 117 kit, fat cat exhaust, and dyno tuned with pv. 107/122 hp/tq. Also upgraded lifters to s&s premium w/o travel limiters, and se adjustable pushrods.
Thank you.
Old Mar 28, 2019 | 06:12 AM
prodrag1320's Avatar
prodrag1320
AV&V or kibblewhite
Old Apr 6, 2019 | 02:40 AM
Nickd2689's Avatar
Nickd2689
Thank you. Are av&v springs the ones that Harley and s&s (an many others) sell as their own? Would you go with slightly stiffer springs for a 259e cam or just replacements? I know stiffer springs can increase wear but I’m going in circles reading about whether or not I should go with stiffer springs. I do tend to ride higher in the rpm range.
Old Apr 7, 2019 | 05:49 PM
djl's Avatar
djl
The OEM beehive springs will accommodate the lift and, IIRC, those are AV&V springs with a seat pressure of 140psi. Nothing wrong with those springs for most street applications. The SE Performance catalog will recommend the SE "race" springs designed to operate properly up to 7000rpms but unless the motor will see that rpm range, the race springs are overkill and will contribute to valve train noise. If a bit more than stock spring pressure is desired, shims are available. JMHO.
Old Apr 8, 2019 | 05:49 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
We use KPM, or AV&V here as well.
.650" are used on both our HMM Stage III Super-Tour, and Stage IV Heads, which we use on 117"s.
Scott
VDeuce
Milwaukee Eight (M8)
11
Jun 3, 2023 03:29 AM
Manfire
Engine Mechanical Topics
Feb 9, 2018 10:25 AM
glidein wide
EVO
29
May 29, 2017 10:24 AM
homiegfunk53
Exhaust System Topics
Aug 1, 2013 06:04 AM
CTP
Ironhead
Feb 15, 2008 08:02 PM
