New to Me 2004 Road Glide.
Old Aug 12, 2019 | 01:22 PM
Garrman's Avatar
Garrman
Hi Dan,
Sorry, I misunderstood your [previous post.
The RG shifts into first with a very mild clunk and shifts though the gears smoothly. The RK (retired police bike) has always had a much more pronounced cluck when shifting in to first. When shifting gears, the pedal does this weird thing were it sort of springs or kicks back slightly. There also seems to be an odd noise coming from the general area of the primary. Lately there is an intermittent grinding when putting the bike in gear, like the clutch is not fully disengaging.
I have done fluid services and clutch adjustment as per the service manual several times but the shift issues persist. At one point, I found that the c-clip that holds the primary shoe had popped off and the shoe was bouncing around. This makes me suspect an issue with the compensator, clutch or transmission shaft.
Am I barking up the wrong tree? Any and all suggestions are appreciated.
Other than that, the bike is an absolute blast to ride. Good power and handles well for a bike of that size.
Regards,
Garrman
Old Aug 12, 2019 | 06:04 PM
Pop-pop2's Avatar
Pop-pop2
I would suggest to change the cam chain tensioners. I bought an '03 rk with 6700 miles on it. Put 3k on it, and did the 10k service. Tensioner shoes were toast. Found out that when they sit, they "dry out" so to speak. I had .002" runout, so I went gear drive.
Pop
Old Aug 13, 2019 | 10:04 AM
Fat11Lo's Avatar
Fat11Lo
Originally Posted by Garrman
Hi Dan,
Regards,
Garrman
What year is the Road King, I had one a couple of years ago, an 08, that the clutch hub had a **** ton of runout, the owner had no idea anything was wrong until I fixed it, then he couldn't believe how easy it was to shift and he said he had never been able to find neutral with it running
Old Aug 13, 2019 | 11:11 AM
Garrman's Avatar
Garrman
Hi Chuck,
2002 FLHPI. The clutch hub is one of the areas I suspect of being the problem.
Besides a hard time finding neutral, what other symptoms did your customers bike exhibit?
Thanks,
Garrman
RED_5
Milwaukee Eight (M8)
Nov 14, 2022 08:58 AM
kpb46
Motorcycles For Sale
Sep 13, 2017 01:07 PM
Drok
Welcome Area Only
22
Nov 17, 2014 10:35 AM
redrott
Oct 20, 2012 08:48 PM
XXXRacing
Oct 15, 2010 06:50 AM
