Xmas in October
Old Oct 25, 2019 | 02:21 PM
eighteight's Avatar
eighteight
Thank you again for your knowledge !
Old Oct 27, 2019 | 07:28 AM
prodrag1320's Avatar
prodrag1320
with the parts you have,it should be in the 110/115 area,our 98" kits with S&S 570 usually land in that area
Old Oct 27, 2019 | 07:44 AM
470004's Avatar
470004
Good luck with your build.
Old Oct 27, 2019 | 07:38 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Do you not think 1.2 is achievable out of a 98" build?
Old Oct 28, 2019 | 09:20 AM
eighteight's Avatar
eighteight
Understood that actual C/R would always be lower than theoretical, did NOT realize how much influence cam specs could have on these numbers.
Took djl`s advice ( thank you) and experimented with the BB calculator. I arrived at the following recipe(s) which hopefully minimize fuel sensitivity ( my concern) and tuning woes. ( again djl )
.045 head gasket / 3cc pistons/ assumed 83cc heads/ assumed .005 below cyl deck
current 510`s yield 9.35:1 194 CCP
570`s 9.27:1 192
I assume these are close enough to be interchangeable regarding fuel & tuning
I assume the 570`s will generate slightly more hp.
That being said, I`m not chasing a hp number and rarely encounter the stock rev limiter
Per S&S: 510`s are 3-5.5K rpm c/r under 9.7 and stock heads 570`s 3.2-5.7K rpm also "bolt on" ( been running the 510`s for 17 years and seem to be quite linear , no complaints )
Old Oct 28, 2019 | 11:35 AM
eighteight's Avatar
eighteight
I`m sure I`m over analyzing and I appreciate everyone's patience and input
The S&S recommended C/R of under 9.7 is the static number, if I fiddle the calculator to give 9.7 static it creates 8.8 corrected
My desired recipe of 9.35 is a half point higher, is that a concern for detonation ? S&S chat line say`s yes
I could buy the 570`s w/ inner gears (p/n 33-5166)
I can spin a wrench and did several iron XL & shovel top ends back in the day, There were fewer variables and a lot less readily available knowledge back then !
Evo & T.C. work has been limited to cam changes up to now
I would really like to do this work only once !
Thank you
Old Oct 28, 2019 | 01:26 PM
98hotrodfatboy
If you run a .030 head gasket and increase your static to 10.17:1 with the 40* ivc your corrected would be 9.33 with a 194 ccp. Keep in mind the .030 head gasket will help to reduce the squish winch will actually help to decrease detonation and make it easier to tune..
Old Oct 28, 2019 | 02:16 PM
eighteight's Avatar
eighteight
well then 10.17 and 40ivc leads me to purchasing the 570`s
Thank you
Old Oct 29, 2019 | 10:07 AM
djl's Avatar
djl
Thank you
Don't be afraid of compression. My 98" is running fine at 10:1 corrected CR and 212psi CCP but it is an EFI bike and can be tuned appropriately; I would not run that compression in a carbureted motor.
Having said that, at 10.2 the 570 will be happy but the OEM ignition should be replaced with a programmable ignition as previously suggested. The ignition curve will be important at the level of compression and it will be important to get the ignition curve close ASAP and premium fuel would be a good idea.
a
Old Oct 29, 2019 | 01:40 PM
eighteight's Avatar
eighteight
Thank you.
I assume the O.E. ignition will advance too quickly ?
Hope the Daytona Twin Tec comes with directions !
( Shooting for corrected of 9.36:1)
