Rebuild
Old Nov 25, 2019 | 05:50 AM
Shovels & Vettes's Avatar
Shovels & Vettes
Default Rebuild
Default RebuildI have a 2004 Road King with 124,800 miles on it......all by me. I feel like the engine may be getting weaker, and time for rebuild. Its not burning an ounce of oil between oil changes, and I will do a compression check to see how it is sealing. But, if the time has come, my question is whether or not I should touch the bottom end. I have used Screamin Eagle Synthetic in the engine, and HD recommended oil in primary and trans since after original break in, every 5000-6000 miles. My plan for top end is upgrade to 95 or 96 inch, from my current 88, using either SE or S&S parts. But as for the bottom end, my research shows that there are several vendors who do a decent job at the bottom end work including welding the crank to prevent shift, etc, and looking for recommendations. I could go another summer, and might, but eventually I want to do it before any catastrophic occurs. Thanks in advance.
Shovels & Vettes
Mar 20, 2026 07:57 AM
BCMopar
EVO
25
Oct 30, 2020 10:51 AM
ranger50
Oct 17, 2010 10:36 AM
moderndaydrifter
Exhaust System Topics
Feb 26, 2008 11:19 PM
BAM
Oil Archive (no new posts)
Oct 6, 2006 10:34 PM
