Unknown Issue
Old Dec 4, 2019 | 01:34 PM
Pearlsnapz's Avatar
Pearlsnapz
Stage III
Default Unknown Issue
Hi All,
I am at a loss with that's wrong with my bike. 08 Ultra Classic.... When I bought the bike everything was fine, I removed the baffles from the stock pipes and everything was still running good, less fuel mileage but running decent. There was an constant flame coming from the exhaust and burning the pipe, and horrible backfire. So I bought a fuelpak 3 to hopefully correct it. That's when everything went down hill, the flame didn't stop, still backfiring like crazy regardless of what time Vance and Hines sent me... I went ahead and bought a pair of megaphone slip ons and tuned again. Backfiring and flame has stopped but I have basically lost all power in 6th gear. I can run it up to 90 95 in 5th an the moment shift to 6th, I slow down, throttle wide open.
I checked timing and everything I can think of, I'm low on funds so taking it to the dealership is not an option... My next route to check would be the valves. However, is there something else I could be missing? Is there a way to check which cylinder might be messing up? Maybe burnt a valve? Is there a way to narrow down which cylinder might have the burnt valve without taking the motor apart. I can get the valves done if that's what's needed but I can't go replacing parts that are fine, which I'll have to do if I just guess and it's the wrong cylinder.
Thanks in advance.
Old Dec 4, 2019 | 10:36 PM
Max Headflow's Avatar
Max Headflow
I know what the issue is.. You messed with the bike.
Old Dec 4, 2019 | 10:45 PM
50pannmore's Avatar
50pannmore
Put the restrictive exhaust back on and Flash the stock map back into your bike with your fp3 and see if that clears it up I seriously doubt you have a burnt valve or anything else wrong with it other than and I hate to say it probably the fp3 I have a fP3 on my 15 Road Glide with thunderheader slip ons and it started running like s*** so I ran Auto-Tune and then reflashed it and set my throttle Progressive tivity back to moderate and it started running a lot better our local dyno tuner has a box of old fp3
Old Dec 5, 2019 | 06:56 AM
marcodarq's Avatar
marcodarq
Have you checked your fuel pressure?
m
Old Dec 5, 2019 | 10:19 AM
V&HBryan's Avatar
V&HBryan
Originally Posted by Pearlsnapz
Hi All,
Thanks in advance.
Sounds like you may have an issue other than tuning, but at least I can help you cross something off your list.
Navigate to the Customer Support Menu, select Vance and Hines Support, then scroll down and press Upload ECU Content. From there send me an email at FPPro@VanceandHines.com with the details of the parts installed on your bike, and the last 6 of your VIN, and I'll look into your tune personally.
Old Dec 5, 2019 | 02:41 PM
Pearlsnapz's Avatar
Pearlsnapz
Stage III
Thank you. I've tried doing this before and nothing seemed to change when this came back.. I will do this after work.
wengerda
Oct 2, 2018 01:27 PM
RustyCage
Aug 7, 2014 04:10 PM
Chris07
Oct 11, 2013 11:59 AM
FASTTED
Exhaust System Topics
May 19, 2012 05:52 AM
NCtaxguy
Apr 10, 2010 11:52 AM
