Got Engine Codes
Old Jan 12, 2020 | 02:45 PM
barneyboy's Avatar
barneyboy
https://www.fuelmotousa.com/p-29661-...ble-codes.html
Old Jan 12, 2020 | 02:54 PM
golfblues's Avatar
golfblues
ECM Y
p0132. FRONT OXYGYN SENSOR HIGH/ENGINE RICH
0n001439-01 probably a part number
BCM Y
62116 THIS IS B2116 fuel pump output open
62271 THIS IS B2271 BCM VOLTAGE LOW
SPD0 Y...not sure if the D is a D is way a funny character
u0100 LOST COMM WITH ECM
Also this showed up somewhere pn41000351a this is just a part number
I would pull the connector off the ECM and make sure it's all clean. Put some Dielectric grease on the contacts and plug it back in. Clear all your codes and start it up and see if they come back
Old Jan 12, 2020 | 03:06 PM
mstrlucky74's Avatar
mstrlucky74
Thanks a lot guys.
Old Jan 12, 2020 | 05:05 PM
barneyboy's Avatar
barneyboy
There is likely nothing wrong with your BCM. It is the module that generated the DTC's, and it's doing it job. Replacing the BCM would likely accomplish nothing, other than lightening your wallet. It's difficult to diagnose DTC's over the internet, without knowing the specific details (what work was recently done) that may have triggered the DTC's.
Old Jan 12, 2020 | 05:29 PM
golfblues's Avatar
golfblues
But one of his codes were he lost communication with the ECM. That's why he should unplug it, make sure there's no corrosion and put some Dielectric grease on it and plug it back in clear the codes.
Losing communication with the ECM could have caused the other codes.
Old Jan 12, 2020 | 05:43 PM
mstrlucky74
I just have to locate the ECM. I tried to do a little YouTube search and couldn't find much.
Old Jan 12, 2020 | 05:47 PM
MURPHCC1's Avatar
MURPHCC1
do you have a Factory Service Manual?
Doesnt sound like you have much experience wrenching.......
Old Jan 12, 2020 | 05:52 PM
golfblues's Avatar
golfblues
#14 behind cover #15
Old Jan 12, 2020 | 06:14 PM
barneyboy's Avatar
barneyboy
There's 10000000+ YouTube vids, 100000 pertain to shade tree mechanics, take your pick.
Old Jan 12, 2020 | 06:39 PM
MURPHCC1's Avatar
MURPHCC1
Once you remove the ECM and clean the contacts and reinstall, clear the trouble codes.
