Budget 88” horsepower question
Old Feb 12, 2020 | 09:57 PM
Andrewsreed's Avatar
Andrewsreed
Default Budget 88” horsepower question
Hello all, i have a stock 88” in my ‘02 Road King, with S&S 509 cams/fueling lifters/powervision that i installed last year when i had to fix the cam chain tensioners... bike has a Baker OD6 and while i can hang with the new bikes, my little motor is on the struggle bus. Get about 36 mpg’s and really falls on its face on the top end. Crossing the pass isnt its favorite activity, but it happens alot.
I’d love to go 98” and ported heads but i just upgraded to a pro-pipe, enforcer wheel, and paid the tax man quite a bit, so a full step-up isnt in the cards this year. I am now looking at some budget friendly ideas to bump up my power just a bit.
im hearing that 06+ heads flow a bit better, and i found a clean set locally in great shape for a steal of a deal. Im thinking of snatching those up, using a 0.030 head gasket to bump the compression up slightly and helping the flow, as well as opening the door for bigger cams if i wanted to.
Will this actually yield any tangible results? According to the bigboyz calculator, ill be at about 8.6 cr corrected. If i were to swap to an s&s 551 cam maybe later this summer, i would then be at about 9:1 corrected.
I rack up alot of miles and would love just a bit of a boost if possible. This wont break the bank either.
Old Feb 12, 2020 | 10:57 PM
rhuff's Avatar
rhuff
I'd just bore to 95" or 98" Don't know what the 509 would be at CCP wise at 98", but I'm pretty sure they were just fine in the 95". Doesn't cost much to bore or for pistons. Don't know if this is out of your price range. I'm kind of a believer in saving your money to do it right once. Or else you do it twice and spend more money. Some people enjoy the doing things in stages. I don't like to waste money.
Old Feb 13, 2020 | 12:19 AM
Andrewsreed
the heads are 200 for the pair and in great shape. I havent found any pistons cheaper than that... i found a pair of SE cast 95’s that were about that range i think. Next year i’d like to go all out and go 98” with nice forged pistons and ported heads, so i dont really wanna half-butt a 95” right now (along the lines of your logic, not duplicating work).
In essence, im suggesting a simple head swap for better flow, wondering if theres any legitimate power gain from that simple change. Cost would be heads plus gaskets, i have a powervision with autotune so dyno wouldnt be necessary.
Old Feb 13, 2020 | 09:42 AM
djl's Avatar
djl
Not going to see much benefit from better flowing heads with out higher lift cams. If you have long term plans to build a beefier power plant in the future, leave things alone until you can afford to bore, use the later heads (worked or not) and replace the 509s with a better cam set. In the short term, changing final drive ratio will help with the passing situation. Might require a belt change as well if you go down two teeth on the trans pulley.
Old Feb 14, 2020 | 05:59 AM
Hillsidecycle.com's Avatar
Hillsidecycle.com
Sponsor
Our HMM #0980 98" kits boring your cylinders, forged pistons, complete Cometic top end gasket kit, ring end gaps are set, and installed.....still only $675.00
Not made in China.
Scott
Old Feb 14, 2020 | 02:27 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Not made in China.
Scott
There's the best bang for your buck.. add those $200 heads and a better cam and now you have something
Old Feb 14, 2020 | 03:48 PM
eighteight's Avatar
eighteight
Agree, and if it’s not in this years budget it certainly won’t kill you to wait a bit and do it all as a package
those heads won’t “spoil” sitting on a shelf!
Old Feb 15, 2020 | 11:20 PM
SafetyFifth's Avatar
SafetyFifth
Ill echo what others have said here. Dont waste your time putting those newer heads on your 88. Not much improvement. Now down the road when you bump up to a 95 or 98 those heads will make a difference. I got a take off set of 103 heads and sent them off to be ported and polished. Turned out real nice.
Also, your current stock intake manifold will work on those new heads but you will need the 06+ style intake flanges as the bolt pattern changed.
Old Feb 16, 2020 | 02:48 AM
Andrewsreed
Thanks for the input fellas, ive spent the last few days researching from this site what would be a good, budget friendly build. I learned there were more options than i thought- i called the local machine shop/builder and discussed a few services based on the info ive read here. so ive settled on a plan i can probably pull off before the full swing of summer:
3 angle valve job/seals/balance chamber cc’s by local machine shop on my 06+ 96” head
Stock set of cylinders bore to fit SE cast 10.25 pistons
S&S 570CE cams (i really dont wanna mess with releases if its avoidable)
assuming these heads don't need much of any milling to equalize, the BigBoyz calculator puts me at 9.77 corrected compression and just a hair over 205 ccp. What do you guys think? Seems to be streetable, torquey, probably sound wicked and would probably run well on 91 octane right? Any info is appreciated, this is my first top end build on a Harley, and hoping it would provide enough power to take full advantage of the baker i installed last year. Hopefully will pair well with my Propipe and big sucker. I have a powervision w autotune as well.
thanks in advance guys! This group is awesome!
Old Feb 16, 2020 | 04:35 AM
eighteight's Avatar
eighteight
[QUOTE=Andrewsreed;18879208] the BigBoyz calculator puts me at 9.77 corrected compression and just a hair over 205 ccp.
I would add manual compression releases just to be on the safe side. Or EZ start 570`s
Others may disagree.
I think your combination will run GREAT !
