Need help with M8 counterbalance shaft install
Old Jun 14, 2020 | 03:53 PM
Camaro67's Avatar
Camaro67
Default Need help with M8 counterbalance shaft install
Need help with M8 counterbalance shaft install. I removed counterbalance shaft to repair engine block and now need to know how to reinstall. The counterbalance shaft has two gears on it, one has a timing mark but the one under it does not.It will rotate about 8 teeth. The service manual I have shows only the top gear timing not the thinner gear.I went to harley dealership and they told just to stick it in.I did not like what they said.There must be a proper timing mark or I am missing something. NEED HELP
Old Jun 17, 2020 | 08:47 PM
Steve Cole's Avatar
Steve Cole
HD EFI Guru
Are you talking about the spring loaded gear, if so, as I recall you have a small hole in both gears you align first, then lock them in position. Then install the counter balancer in the case and remove the part in the two gears holding the holes in alignment. This allows the spring loaded gear to release and keep the gears from rattling.
Old Jun 23, 2020 | 05:42 PM
Sparky357's Avatar
Sparky357
Right around the 28 minute mark
Catmanjoe
Feb 1, 2020 09:08 AM
frankiefire702
Nov 18, 2011 01:16 AM
wheeldawg
Mar 8, 2009 08:42 AM
GAdog
EVO
Sep 7, 2007 05:13 PM
