'08 Heritage - Replacing a compensator
Old Jul 8, 2020 | 10:16 PM
MLZ's Avatar
MLZ
Default '08 Heritage - Replacing a compensator
I recently bought an '08 Heritage with 7,000 miles on it. It starts great, but always with a loud clang or bang. Everything I've read makes me think it's the compensator, and that it can be replaced. My question is, does it need to be replaced? Is it causing damage, or is it just annoying?
Old Jul 12, 2020 | 11:15 AM
Crotonrz's Avatar
Crotonrz
Assuming it's the compensator, which would be extremely rare with that low mileage, then yes, you can eventually cause some damage. If the compensator isn't functioning as expected, there are jarring impacts to starter, clutch pack ring gear, clutch pack main shaft splines, primary chain. In ordinary function a compensator allows for a ramped engagement of engine power (as well as start up), when they are bad the ramping function can become jerky as wear and tear does it's thing to metal and it is not as smooth as it should be, or, worst case, can cause the ramps to jump over each other when wear to the spring pack/ramps results in enough slop to allow it. Is this starting issue worse when bike is hot?
Old Jul 12, 2020 | 02:07 PM
MLZ's Avatar
MLZ
If it's rare for a bike with such low mileage, what else could it be if not the compensator? I will add that after a couple of hundred mile ride, it didn't seem to do it. But even after warming up on 20-30 mile rides, it does it.
Old Jul 12, 2020 | 04:01 PM
djl's Avatar
djl
I don't think it rare for the '08 model year. The MoCo has "upgraded" the later compensator several times. There are several aftermarket solutions and, IIRC, the last MoCo upgrade works well. Do some research on the compensator issue and I think you will come to the conclusion that it should be replaced.
Old Jul 12, 2020 | 04:02 PM
60Gunner's Avatar
60Gunner
It wouldn't surprise me one bit to have it be the compensator at 7,000 miles. Especially on an 08. It's been a work in progress and even the latest SE compensator on '14+s leaves much to be desired. I just got rid of one on my '13 that had significant wear at 30,000 and replaced with a solid 30 tooth compensator eliminator from Evolution Industries. Drop 6+lbs. of rotating mass in the process. They make a 34 tooth if you wanted to leave the gearing the same.
Old Jul 12, 2020 | 05:14 PM
Nitro 54's Avatar
Nitro 54
The clunking could be caused by the light weight oil Harley puts in the transmission assuming it hasn't ever been changed.
Old Jul 12, 2020 | 05:19 PM
60Gunner's Avatar
60Gunner
He's not even talking about putting it in gear. Just starting it.
Old Jul 12, 2020 | 07:55 PM
MLZ's Avatar
MLZ
Thank you, gentlemen. This helps.
Old Jul 12, 2020 | 08:10 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Put a battery in it first. More the likely, that is what it is. The compensator if that weak would show signs when shifting also.
Old Jul 12, 2020 | 08:39 PM
Rik17FLH's Avatar
Rik17FLH
Just a question, does it make the same noise whether you start it with the clutch pulled in? I don't mean in gear.... I just mean in neutral with the clutch disengaged.
