Shovelhead Lifters
Old Jul 14, 2020 | 05:20 AM
evangenj's Avatar
evangenj
3rd Gear
Default Shovelhead Lifters
I just bought a 1980 FXE. Apparently motor was rebuilt 8k miles ago. Just been reading up on the basics of a Shovelhead. And I was seeing if there is anyway to distinguish if the lifters are still hydraulic or were they converted to solid. I just want to do the proper adjustment.
Old Jul 14, 2020 | 11:51 AM
bustert's Avatar
bustert
the lifters should have been solids. i converted my 74fx to hyd.
one way to tell is run the engine and stop it and open up the p/r tube and set valve fully raised and wait. the spring pressure will collapse the hyd and when you run the valve down, you will have slack. if the p/r were changed to non adjustable, you have your answer also.
Old Jul 14, 2020 | 02:37 PM
evangenj's Avatar
evangenj
3rd Gear
Ok. I will give it a shot. Thank you
Old Jul 14, 2020 | 07:57 PM
kink04fxd's Avatar
kink04fxd
I don't think any shovelheads came from the factory with solid lifters.
Old Jul 15, 2020 | 08:44 AM
bustert's Avatar
bustert
just look into a parts book or fiche. my 1974 fxe had solids.
Old Jul 15, 2020 | 09:15 AM
evangenj's Avatar
evangenj
3rd Gear
I just read in 1953 Harley switched to hydraulic lifters in the Panhead? Maybe some engines still came with solid?
Old Jul 15, 2020 | 09:45 AM
chopper_man's Avatar
chopper_man
Both my 78 and 80 Shovels came with hydraulics. Switched them out to solids when I did the cam in them.
Old Jul 15, 2020 | 03:11 PM
kink04fxd's Avatar
kink04fxd
Page 9 1971-1984 Harley FX parts book. Part# 17920-53A Hyd Lifter. 1971-1984 FX All models. No mention of solids.
Old Jul 15, 2020 | 04:54 PM
bustert's Avatar
bustert
yep hd worked on putting in hyd lifters from ww2 times and the pan had them. i def had # 18570-38 and # 18556-57 screw and jam nut in my 1974 fxe. hd had a rep for not throwing anything away so parts could transcend several years. maybe it was a camming thing or model thing. parts fiche for that year def shows them, check out st. charles hd fiche. when i re-geared the tranny and changed cams, i went hyd, chryslers to be exact, from the hd shop. they were old school, used reservoir instead of flow through.
Old Jul 16, 2020 | 07:59 AM
kink04fxd's Avatar
kink04fxd
Those 2 parts you are refering to are part of the pushrod assembly. Thats how you adjust the hyd lifter.
