Checking camshaft and breather end play with new gasket?
Old Oct 6, 2020 | 09:37 AM
Lakerat's Avatar
Lakerat
Cost of gaskets is relatively cheap, so buy 2 identical gaskets and use one for clearance checks, toss it and use the other one for final installation.
Old Oct 6, 2020 | 07:16 PM
Adam76's Avatar
Adam76
Originally Posted by djl
I have re-used MLS head gaskets after checking V to P clearance many times. The head does not need to be torqued to spec to check V to P clearance. Unless the TDC lift is .200" or greater and heads haven't been decked, V to P clearance is most likely not an issue but should always be checked. The OP has a couple of options but there is an option that is a little more time consuming but prevents the risk of bending a valve and can be used with or without the head gasket and is now my preferred way to measure V to P. clearance when running cams with lifts > .600" and TDC lifts > .200".
Remove the valve springs and with the valves firmly seated measure and mark (magic marker) the TCD lift plus .060" or whatever he uses as the minimum acceptable clearance. Attach the head to the cylinder and open the valve up to the mark; the seal should hold the valve. Gently rotate the crank to push the piston up to TDC and if no contact; your golden. However, if there is contact, mark the distance the valve is pushed up. The distance between the new mark and the original mark at TDC plus .060" will tell you how big of a problem you have and you won't have bent a valve. You still have the thickness of head gasket to consider as well.
If the OP chooses the clay route the head gasket can be installed and the head snugged down but not torqued to spec so it can be reused after checking V to P clearance. This route does require converting a couple of lifters to solids and does present the risk of bending a valve; doesn't take much. However, as previously said, if TDC lift is less than .200", that risk is minimized. I am assuming that the OP knows how to use the clay method and will not use solder.
Thanks djl, that's great info. I don't have a valves spring removal tool to use your method - which sounds like a great method. I will have to try and beg, steal or borrow a set 😂
Otherwise, I will have to use the old clay method.... snug the heads down only, and then use the copper gasket sealant for final install that 98hotrod suggested?
Thanks again. 👍
Old Oct 6, 2020 | 07:18 PM
Adam76's Avatar
Adam76
Thanks 98, I haves heard of this stuff before - but can't remember whether it was advised to use our not to use?
So you are not joking, you are actually recommending this product?
Thanks. 👍
Old Oct 6, 2020 | 08:45 PM
98hotrodfatboy's Avatar
98hotrodfatboy
Thanks. 👍
Yes i have actually used it on a 10.8:1 static comp motor.. no issues... A light coat on each side..
drm1978
EVO
14
May 16, 2020 08:04 PM
2ndgenmarine
Mar 27, 2020 04:09 AM
bstorer
EVO
38
Mar 9, 2020 09:31 AM
sisco683
Engine Mechanical Topics
Oct 9, 2017 05:19 AM
Wakko47
May 28, 2012 01:18 AM
