Screamin Eagle Heads
Old Oct 18, 2020 | 07:47 PM
RudyInfante's Avatar
RudyInfante
Stage IV
Default Screamin Eagle Heads
Hello, Is it possible to simply put screamin eagle heads on a TC96 without doing anything else? I am recommending a complete stage IV, but all he wants is screamin eagle heads on a stock motor. I've never seen this done. Thoughts?
Thank you
Old Oct 19, 2020 | 06:15 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
You can certainly put them on but it'll be a waste of good money. There won't be much of if any horsepower or torque gains to be had running just a stock engine.
Old Oct 19, 2020 | 06:37 AM
prodrag1320's Avatar
prodrag1320
not a good idea,with cams & the proper compression for those cams,it will work great,but simply installing heads will most likely result in a performance loss.going to atleast 103 or even better yet 107 would also be highly reccomended
Old Oct 19, 2020 | 06:47 AM
rigidthumper's Avatar
rigidthumper
Which heads? Some will keep it a slug, others will make it worse
Old Oct 19, 2020 | 09:02 AM
RudyInfante
Stage IV
Ok, so this is what I thought. Just wanted to double check to make sure I wasn't going crazy. Thank you for your feedback!
R
Old Oct 26, 2020 | 11:35 AM
Slingshot383's Avatar
Slingshot383
Now, if you get the correct pistons at the same time, setting compression to match the needs of the cam you are using, it's a different story.
Old Oct 26, 2020 | 11:51 AM
RudyInfante
Stage IV
Thank you
Old Oct 26, 2020 | 02:53 PM
djl's Avatar
djl
I don't think they are still available but if the heads happen to be the early SE Performance heads, they would be an excellent addition. Back in the day when they were available, there was a configuration of those heads, 95" displacement and S&S570 cams that was a consistent 100/100 combination known as the "Hippo" build after the creator who is no longer with us. The SE Performance heads came decked from the factory about .050" for smaller chambers, 78cc IIRC which provided the compression boost to make the TQ/HP.
Old Oct 27, 2020 | 03:32 AM
cgmartine's Avatar
cgmartine
My 2000 Springer has Screaming Eagle CNC ported heads, making it a 107 ci. It has lots of power. It required manual compression releases. It also has a six speed trans.
Old Oct 27, 2020 | 05:40 AM
OldEnuf2NoBtr
I hate to tell you this but the heads alone won't give your bike a 107" engine. That will take other parts to accomplish.
