Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
Just finished my 88 > 95 build and all went well in many thanks to this forum
The only issue seems to be some top end noise that I think I can eliminate with a pushrod adjustment from 2.5 to 3.5 turns. I have SE Adjustable (18404-08 @ 24 tpi) with S&S Lifters so I have them at 2.5 turns per instructions (also installed rocker lockers)
My question is can I simply pop the PR clips, loosen the locknuts and add a single turn to bring me to 3.5 which seems to be the sweet spot from my forum searches on the subject.
If not and I need to do the adjustment over from start are there any precautions I need to take when removing the pushrods do I just back them down and remove them 1 at a time then get my lobes on base get to zero lash and add my 3.5 turns?
you can do what you are talking about. i would not go to 3.5 turns, the SE pushrods have a courser thread pitch, 3.0 turns should be just fine. get the cam for the cylinder that you are working with on the base circle first, then procede.
m
what kind of noise do you have? make sure that your rocker boxes have enough clearance around the valve springs while you are in there.
thanks to all , i ended up doing the whole process over and did the 3.5 turns. the motor quieted down and now sounds great.
it was a tapping sound now gone. i did put in the rocker lockers when i was puting it together.
Next up is to seal up the rings
i could always ba k off 1/2 turn if 3.5 is to deep.
i found many opinions on this and i thought 3.5 was the sweet spot
thx
