Compression release question.
Old Dec 24, 2020 | 05:10 PM
djl's Avatar
djl
Originally Posted by djl
Don't disagree with installing compression releases; they extend battery and starter life. However, static CR is really not the criteria for deciding if CRs are "needed" or not; the criteria is CCP. In the OPs case, even with 10.5 static, CCP is about 9.3 193 psi if his listed specs are correct. At 9.3 193psi CCP, IMHO, CRs are not "needed" but they certainly won't hurt particularly since the heads are already prepped for them.
I need to correct the previous post; I recorded corrected compression, not CCP; brain fart when transposing data from compression calculator to the post; corrections hi-lited above. This is the second brain fart of the year; really slipping.
Old Dec 24, 2020 | 06:57 PM
Notgrownup's Avatar
Notgrownup
No matter what is good or bad, since you have the heads off it’s time to get the CR going. The bike will start so much better. Mine sure did.
Old Dec 25, 2020 | 06:44 AM
2009blackpearle's Avatar
2009blackpearle
what year is the bike you may have to add wiring kit and move termiinals in fuse box around my is a 2009 ultra plugs are under tank but wires on fuse box have to be moved around using a wiring kit from harley if u can even get it, lots of parts for the twin cam have vanished since the m8 came out
Old Dec 25, 2020 | 09:25 AM
eighteight's Avatar
eighteight
I believe the OP is adding MANUAL C/Rs
Old Dec 29, 2020 | 03:15 PM
tinymike66's Avatar
tinymike66
Yes
Bike is 2001
Old Dec 29, 2020 | 03:16 PM
tinymike66's Avatar
tinymike66
Originally Posted by Hillsidecycle.com
Once we crest the 10.0 cr number, in those, we install them.
Btw, that 257 will be soft on the bottom, fwiw.
Scott
Very soft on bottom. But those cams light up at 3000rmp and just keep going lol
Old Dec 29, 2020 | 03:19 PM
Notgrownup's Avatar
Notgrownup
When I was having all kinds of starter grind issues, my dealer installed 1 manual CR on the rear cylinder, it made such a difference and let the bike crank so much easier, . When I swapped my engine to a 2014 out of a FLHX it came with the auto CR and I had the dealer wire it to activate them and the bike starts so easy. I can tell the starter doesn't struggle at all. Way Mo betta.
txphatboy
Engine Mechanical Topics
13
May 30, 2021 04:20 PM
Mattbastard
EVO
25
Feb 20, 2018 07:37 PM
Breakout110
Oct 27, 2017 12:05 PM
GibsonSG
27
Nov 28, 2016 07:09 PM
SURFOR Chop
Exhaust System Topics
18
Sep 25, 2011 01:52 PM
