HD SE Adjustable pushrod lock nut
Old Jan 26, 2021 | 06:56 PM
donk_316's Avatar
donk_316
Default HD SE Adjustable pushrod lock nut
Gents,
I have 18422-08 and 18413-08 pushrods and I have lost one of the lock / jam nuts.
They aren't a typical 3/8"-24 nut, they are sized down one size probably for clearance and weight.
Does anyone know a source for these style of nuts? I tried 3 different fastener shops today and they all had no luck for a source.
I don't mind swapping all 4 if need be.
Thanks for any leads!
Old Jan 26, 2021 | 10:25 PM
donk_316's Avatar
donk_316
Found it
https://www.feulingparts.com/sku/4093
Old Jan 27, 2021 | 07:02 PM
djl's Avatar
djl
IIRC, the OEM nuts are 5/16" x 24, not 3/8" x24 and require a 1/2" end wrench not a 9/16". The 3/8" nut will work but could contact the pushrod tube. 5/16 x24 jamb nuts can be found at McMaster Carr.
Old Jan 27, 2021 | 07:07 PM
donk_316's Avatar
donk_316
Nope. They are 3/8" -24. I have them here with me and gone through every local fastener shop.
The issue is that this nut uses one size smaller wrench size than normal 3/8" nut.
Normal 3/8-24 nuts are easy to find but heavier and could possibly contact the pushrod tube since they have the typical wrench size.
Old Jan 28, 2021 | 07:56 AM
470004's Avatar
470004
I had problems with these nuts, but they cracked after installation. They were 3/8-24 with a 1/2" hex. I got replacement from Smith Brothers Pushrod; https://www.pushrods.net/.
Old Jan 28, 2021 | 08:07 AM
bustert's Avatar
bustert
hd does not sell them???
worst to worst, buy some grade 8 nuts and take down the hex. if you buy just one, the shipping would be astronomically high for the value of the nut, cheaper just to get one from hd shop, maybe even the mechanic would just toss you one from a plunder pile.
Old Jan 28, 2021 | 08:36 AM
djl's Avatar
djl
Originally Posted by donk_316
Nope. They are 3/8" -24. I have them here with me and gone through every local fastener shop. The issue is that this nut uses one size smaller wrench size than normal 3/8" nut.
You are right, got my wires crossed. I have broken the nuts that come with the SE Quick Adjustable Tapered push rods and had to get some standard Grade 5 nuts from local hardware store and use the bench grinder to take down the flats from 9/16" to 1/2". Locked both nuts on a fastener, flats aligned and started grinding.
Old Jan 29, 2021 | 01:52 AM
2009blackpearle's Avatar
2009blackpearle
3/8-24 when my aluminum ones or whatever light weight funky stuff they are made of cracked i too ka 5/16 nut drilled out and re tapped it to 3/8-24 more or less original size again
Old Jan 29, 2021 | 01:13 PM
djl's Avatar
djl
That is the other way some have solved the problem. I believe the MoCo has addressed the issue and not an issue now.
Old Feb 4, 2021 | 01:45 AM
donk_316's Avatar
donk_316
Well, I bought 10 nuts... for spares and locals who might need one.
After shipping, "import fee" from DHL and currency exchange. EACH nut cost me $13 cdn...
