Engine Mechanical TopicsDiscussion for motor builds, cams, head work, stripped bolts and other engine related issues. The good and the bad. If it goes round and around or up and down, post it here.
I have an 09 flhx that’s been modified. Having some valve train noise. Upgrades are dark horse crank S&s 10.6:1 pistons woods 999-6 cams s&s oil pump and cam plate. Woods alpha directional lifters. Adjustable pushrods. Head work. 58mm throttle body upgraded rocker arm support plate s&s roller rockers. Any advice is much appreciated I’ll try and post a video
Could be as simple as a mal-adjusted pushrod... but I'm certainly no authority in this forum. Will sub to the thread. For what it's worth: pushrod actuated air-cooled engines are supposed to be noisy like a 1920's sewing machine. I've got an angry one in the garage.
Have a look around my website, might be just what you need
John @ Rockout
__________________________________________________ ____ For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
I found that when I went to adjustable s&s pushrods they would touch my stock pushrod tubes. Causing a tick. I chased my tail doing rocker lockers which helped but didn't kill the tick. I even shimmed the rocker arms to take some of the slack out. Added half a turn on my pushrod adjustment.
That does not sound like Lifter noise.. I would pull the rocker covers and inspect for rockers tapping the cover on the inside.. I sounds like a clearance issue...
thank you I will take my covers off and see I did take out the webbing where they said to in the instructions for the roller rockers.
Not sure how different the covers are from 09 to 15 . I am running the same cams in my 15 rgs with my 107 build and didn't have to clearance the covers.
Are you running new rocker plates with S&S Roller Rockers? The arm for the valve is a lot higher in the forging to increase the support for the roller.
Checking for witness marks on the underside of the rocker cover is a good idea. However, Wood cams are know to have faster ramps; roller rockers are noisier than OEM and if stiffer valve springs were used in the heads, what the OP is hearing may be just a case of "it is what it is"; didn't sound alarming to me.icon-wink:
